1972 Highboy Build Progress
Old Nov 20, 2016 | 10:23 PM
F2501972's Avatar
F2501972
Here's a tread where I posted back in 2014 trying to track down my Grandfathers 1972 Highboy that he bought new. https://www.ford-trucks.com/forums/1...2-highboy.html
Now that I found it I will post pics of the progress. I appreciate any input as I will do most of the work myself.
I'm going to post some pics. Then a few started questions. Thanks - Shawn
Way overdue for a hot bath!
4x4 works / Engine runs.
Needs a lot of TLC. Brakes (MC I think), Tail lights work and one front light. All other lights are a no go. Timing is off I think.
Old Nov 20, 2016 | 10:30 PM
HIO Silver's Avatar
HIO Silver
Ahhha.. there's pappy's rig!
Again, congrats.
Old Nov 20, 2016 | 10:40 PM
F2501972's Avatar
F2501972
This is the truck on a hunting trip in 1974 Canada
My Grandfather is on the right
Guess someone thought I should be covered in red LOL. That's my Grandfather on the right of course. He was a WW2 Navy gunner. Not sure if I have the term correct but when this all came together I actually saw the truck for the first time in over 20 years on Veteran's Day and bought it that day. I even put Veterans Day on the Bill of Sale. That would have put a smile on him! It was a long hunt for the truck as well. Took several years of trying off and on.
Old Nov 21, 2016 | 03:19 AM
GaryKip's Avatar
GaryKip
I'm sure he's proud that you have it.
Old Nov 21, 2016 | 07:42 AM
cstoyer's Avatar
cstoyer
Good truck a great story. Look forward to the updates.
Old Nov 21, 2016 | 10:22 AM
72CC428's Avatar
72CC428
Your story brings a tear to my eye. I learned to drive on my dads 65' Dodge 1/2 ton. He was also a WWII vet. We also went hunting and fishing with that old truck.
Old Nov 21, 2016 | 03:13 PM
KsHighboy's Avatar
KsHighboy
Love it! The old pics are awesome of your grandpa and truck.
Old Nov 21, 2016 | 03:53 PM
JEFFFAFA's Avatar
JEFFFAFA
I'll jump on this band wagon also. I think it's Way Cool. Family history is Cool. Git-R-Done. I'm sure grandpa will brighten up the sky with his big O' grin.
Old Nov 22, 2016 | 09:15 PM
F2501972's Avatar
F2501972
I have found a few parts but I can not find the rubber boot for the manual trans or the 4x4 shifter boot. Where can I find those rubber boots? I think they are called a rubber boot but maybe that is the issue.
Thanks guys!
Old Nov 23, 2016 | 04:39 AM
GaryKip's Avatar
GaryKip
I looked in the NPD catalog (12th edition) on page 118 it shows the boot for the transfer case. On page 120 it has a boot, shifter for a 48-52 year truck. But it says see heading 7277 for more boots. Call them at 1-800-521-6104
Old Nov 23, 2016 | 11:36 AM
JEFFFAFA's Avatar
JEFFFAFA
Thanks guys!
T/C boot:
C6TZ7B059A......66/72 F100/250 4X4.
4speed boot:
C6TZ7B118A......67/72 F250 4X4,66/72 F100,and 66/72 F250/350 (except 4X4).
This company shows both in stock.
Nos Parts Source *Fo
913.220.5746
Old Nov 23, 2016 | 12:51 PM
F2501972's Avatar
F2501972
Originally Posted by JEFFFAFA
T/C boot:
4speed boot:
913.220.5746
Thanks - I left a message.
Old Nov 23, 2016 | 12:59 PM
JEFFFAFA's Avatar
JEFFFAFA
You're welcome.
Hang in there. He will call you back. Might not be until tomorrow morning, but he will. Been there, done that myself a time or two. Unless the holiday gets in the way.
Happy Thanksgiving Bud.
Old Nov 24, 2016 | 07:53 PM
F2501972's Avatar
F2501972
Are there any good links or instructions on taking the front end apart? I will need to replace both inner fenders and possibly the drivers side outside fender. I found OEM inner fenders and fender for drivers side. Had a guy tell me (who sold the parts to me) I can do it, just will take some time. Thoughts? Links? Instructions?
Happy Thanksgiving to all - Shawn
Old Nov 24, 2016 | 09:25 PM
HIO Silver's Avatar
HIO Silver
It's rather intuitive.... but there is an order that makes life easier.
Here's the order I recommend. Of course bag and tag your hardware. I also highly recommend taking photos for future reference. Do not rely on your memory because you will forget. Alternatively, reinstall the bolts in the J-nut or U-nut from which they were removed.
Also, if the body panels are decently aligned , drill 1/8-inch holes along the mating flanges and use the drill bit to index the panels during reassembly... a picture is provided below for reference! Drill the hole in an inconspicuous place!!! If the part has left/right and up/down adjustability, drill two holes! i sealed the holes with small wads of 3M strip caulk:
  • Front bumper
  • Grill inserts (and unplug the headlights and turn signals) (70-72).
  • Headlight doors and headlamps.
  • Grill shell assembly with upper valance (three bolts at the fender, three up inside the corner of the fenders, two at the hood latch, two on either side of the radiator from the inside the engine compartment,, likely more.)
  • Lower gravel shield... two or three bolts on each side attaching to the fenders Three along the upper edge accessed from underneath.
  • Unbolt and remove the hood from the hinges (a two-man job!)
  • Hood hinges
... that should get you far enough.
To remove a fender, some bolts are up inside the front wheel well and one or two underneath .. forward of the rocker. There is one bolt behind the fender.. it is accessed through the forward door jamb where the courtesy light switch is positioned!! A ratcheting combo wrench would be convenient.
