1972 Highboy Build Progress
Old Jan 25, 2017 | 02:10 PM
  #256
JEFFFAFA's Avatar
JEFFFAFA
C7TZ16138B
67/72 F100/250 4X4-F350.
67/72 F100/250-4X2-w/super cooling.
This is the only place that shows up on my locaters.
Fred Grande Ford
5867493141
Old Jan 25, 2017 | 02:18 PM
  #257
cstoyer's Avatar
cstoyer
Do you have a picture of your radiator mounted in the truck? Curious as to what the sheet metal looks like that supports the rear mount radiator. I have a 68 250 4x4 that the PO put a 2wd core in with a 2wd radiator. Meaning it is front mount radiator versus the rear mount radiator of the 4x4. So if push comes to shove you could buy the 2wd core and remove the sheet metal from your 4x4 core support if its good Or buy a 2wd radiator to mount to your new core support.
FWIW I screwed up when I ordered a 4x4 replacement radiator not knowing I had a 2wd core support.
cstoyer
Old Jan 25, 2017 | 05:30 PM
  #258
orich's Avatar
orich
f2501972 We need a pictures of how the rad mounts in front on the rear of the Rad?
Orich
Old Jan 25, 2017 | 06:08 PM
  #259
F2501972's Avatar
F2501972
Give me a minute to take a couple more
Old Jan 25, 2017 | 06:10 PM
  #260
orich's Avatar
orich
Okay here's the difference
You have a rear mount now you understand?
Old Jan 25, 2017 | 06:13 PM
  #261
F2501972's Avatar
F2501972
Old Jan 25, 2017 | 06:55 PM
  #262
F2501972's Avatar
F2501972
Yes, now I understand. So I need to make sure it is a rear mount.
Where is that rear mount rad support in your pic :-) Is that sitting somewhere waiting for a new home? :-) Having a hard time finding one.
Last edited by F2501972; Jan 25, 2017 at 07:00 PM. Reason: Where is that rad support?
Old Jan 25, 2017 | 07:15 PM
  #263
cstoyer's Avatar
cstoyer
I have only seen 2wd core supports listed. Maybe someone else knows where to find them.
cstoyer
Old Jan 26, 2017 | 11:59 AM
  #264
F2501972's Avatar
F2501972
This was posted by 1982fordf100 and he says to copy as needed.... Becuase I'm on the search for the rad support thought I would post it...
My Blue oval truck parts catalog the other day in the mail. Very good parts inside of it and some good information about our trucks. They even have the production totals for each model for every year in the front of it. Also alot of other useful information such as decoding VIN's. Since its a free catalog and they are our sponser I'll have to order some parts from them soon.
Here's a list of all the websites that have free catalogs available:
1. Truck Parts & Truck Accessories for Chevy, GMC, Ford & Dodge Trucks | LMCTruck.com
2. National Parts Depot | Restoring American History | Mustang Parts | Camaro Parts | Chevelle Parts | Ford Truck Parts | T-Bird Parts | Firebird Parts | Chevy Truck Parts
3. www.blueovaltruckparts.com
4. Dennis Carpenter Ford Car, F-100 Pickup Truck, 8N, 9N Tractor and Cushman Scooter Restoration Parts
5. The Paddock | Performance and Restoration
6. Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale
7. Centrally located right here in the heart of Oklahoma
Copy and paste as necessary.
Old Jan 26, 2017 | 05:04 PM
  #265
F2501972's Avatar
F2501972
I put tape on to see body lines better. Should there be a spacer bushing between the frame and the truck bed? As you can see my bed needs to come up 1/4 or 3/8 inch.
Old Jan 26, 2017 | 06:19 PM
  #266
orich's Avatar
orich
A man's got a do what it takes to make it look right!
I made up some nylon large 3/8" thick washers the same size as my body mount cushions
to get my cab up to keep the inner part of the tranny hump from rubbing the 5sp o/d tranny. This was when, I was using LMC Cab mount cushions.
I since put back in oem cab mount cushions an a big thanks to one an only the Bumpster King II Jeff.
It took a while to track down all the pieces for the 4wd cushions upper & lower locking insert washers.
Orich
Old Jan 26, 2017 | 06:36 PM
  #267
JEFFFAFA's Avatar
JEFFFAFA
Orich
No problem for one of "my good neighbor(s) next door".
Old Jan 26, 2017 | 07:05 PM
  #268
Brian1971f100's Avatar
Brian1971f100
If you need to do front cab mounts that can effect cab to bed figment. Pull a string don't the front fender to the tail gate to see what the bump line is doing
Old Jan 26, 2017 | 07:26 PM
  #269
F2501972's Avatar
F2501972
Jeff, I agree with orich :-)
Can you confirm that the rubber cab absorbers from page 2 are the correct ones for the 4x4? I'm going to order those and want to make sure they are for the 4x4 cab as well. Thxs
I also looked in the manual books I bought and can not find the right place where they show the bed bolting on or the cab bolting on. Where can I find a 4x4 frame to body diagram? Maybe that will solve part of the mystery.
I'm still searching for a rad support and have a couple leads I found on this link https://www.partshotlines.com/component/phl/search/
Going to make some calls tomorrow.
Thanks guys! I really appreciate my friends on this site!
Old Jan 27, 2017 | 02:26 AM
  #270
F2501972's Avatar
F2501972
Orich
Orich, did you bolt your bed directly to the frame or was there a spacer?
Do you have the 4wd cushions upper and lower part numbers?
Thxs-
