Official NCFTE Works Thread
So here's the deal with the engine: It's the original 400M, needs a new intake manifold as it's leaking exhaust through a port, and it appears to be leaking oil possibly from the head gasket. The truck runs and drives, actually sounds pretty good, no knocks or pings. Trying to make a plan how to proceed so that I'll end up with a reliable truck to haul stuff in the bed and to tow a boat. I have little experience working on cars/trucks compared to most of you fellas, but I'm learning. Thinking about procuring an old motor and rebuilding as much for the learning process as having a reliable power source. Not looking for a hot rod or anything crazy, but I'd love to hear what y'all think about what to put together for my intended uses, ie 4bbl carb, fuel injection, headers, change mounts and put a 390FE in there, etc. I'm not above offering beer and grilled food for anybody who offers to come down and help this summer too, lord knows I can use all the help I can get, LOL.
Josh I am about to start building a deck for my son so there will be several trips to the lumber yard in the near future
The 400 is a torque monster. Doesn't have the "gee whiz that's cool" factor of a 390 or a 460 but it will surely get the job done. Pretty uncommon for it to leak oil at the cylinder head, more likely the valve cover, or like you said around the intake manifold. Both of those jobs aren't too difficult. But you said leaking exhaust through a port, I am not sure how that would end up on the intake side except for that exhaust crossover that they dreamed up during the smog era. That's the EGR thing behind the carburetor, might be easy enough to block it off. I know I had a 302 motor with the same setup and I cut out of a piece of steel to fit and bolted it down. Not because of a leak but just because I didn't want or need the exhaust gas coming back into the intake.
Oh one more thing I want to warn you about, as far as buying a 390 to build up. First off I will say I love a 390 and would be happy to put one in MY truck, but be aware of the old Ford saying "every 360 becomes a 390 on sale day". Nearly impossible to tell them apart, but look at the number of 390's for sale vs 360's and realize that 360's were way more common. And it probably won't be a devious seller either, the person selling it will probably have always been told it was a 390 as well!
As for the 390, to be honest I'd rather stick with a direct swap so I'm not changing too much. Only reason I'm not just pulling my motor to rebuild is because of my limited room to work. Leaving it in will allow me to move the truck around if need be while I work on another motor in my small one-car garage. I think at one point I heard the 390 was just a better motor, but I really have no clue.
I got the brakes hooked up after moving it.
As of right now the to do list is:
Fill/bleed brakes
Finish bolting cage in
Install my new MSD coil
Install new master kill switch
Install hood pins
Tiddy up wiring
Oil change
New air filter
Then we should be ready to get it dirty, and try out my winter upgrades.
It maybe made of alum. and if so they would burn a hole thru them and do what you have......an exh leak and run like crap.
As said you can block off that port with a tin can or better yet pick up a spacer to fit in it's place.
That oil leak, degrease the motor so you can see just where it is coming from. Most of the time it is a valve cover, next would be the intake end seals.
I would not do a 390 FE swap I would stick with the 400. What you said about picking one up is good.
Check out CL and on here in the "for sale" area to see if someone is unloading one cheap that needs a rebuild.
The more complete the better. Also there are a few books on rebuilding Ford motors pick one or 2 up so you have something to go by when building your motor.
IIRC from the get together at Jims you were in the armed forces right? That was the only one I have been able to make, work hours during the week make it too hard.
Dave ----
Once clean you should be able to pinpoint the oil leak.
A few day ago I got home early from work looked into bleeding the brakes on the project by myself, it did not happen LOL
I could not find the bleeder tool from the move down here. Found out my son has it up in CT so he is sending it down, stay tune!
I did find a leak. 1 of the new caliper hoses leaking at the caliper. 1 of the copper washers was too thin and the hose end would bottom on the caliper housing and not getting tight.
I took a washer off 1 of the old caliper and it stopped leaking.
I did leave the bleeders open hopping they gravity bleed till I get the bleeder tool.
Dave ----
picked up a King pin 60, and a sterling 10.25 tonight... Ol blue has 1 tons in its future in a couple years.
Couldn't pass them up for $250...
I'm interested in how you've mounted that swing-out lift you have in the bed.
https://cimg3.ibsrv.net/gimg/www.for...df2c5efcce.jpg
Bed chopped and mounted on the chassis?
Custom mounting plate attached to chassis?
Looks low, is this a stowage/travel position?
