03+ - Brake Dust Update
Old Feb 25, 2004 | 03:21 PM
  #316
D2EBMA's Avatar
D2EBMA
cloud10 -
I believe you're referring to these
https://www.ford-trucks.com/forums/s...t=%25252Bkleen
Of course, better engineering would be preferable.
Old Feb 25, 2004 | 05:14 PM
  #317
austinjorg's Avatar
austinjorg
I talked to the Service Managers at both dealers I have worked with. (1) where I bought it and (2) where I have service done. Both said no way does Ford pay for the pads. The dealer where I bought it said that they have not even replaced any.
So, is Raybestos still considered the best, if so, does anyone know a time frame when they will be coming out with the right pads?
Old Feb 25, 2004 | 05:43 PM
  #318
Dwights's Avatar
Dwights
Ford has not and probably will not replace the pads but some dealers are.
Old Feb 25, 2004 | 07:51 PM
  #319
cloud10's Avatar
cloud10
thanks D2EDMA and austinjorge grweatly appreciated your responses yes i beleive those are the one i was referring too D2EBMA do they work ok. thanks!!!
Old Feb 26, 2004 | 06:17 PM
  #320
mrslate's Avatar
mrslate
All, just did some checking, Advance Auto Parts here in Ohio lists a ceramic pad by Friction Master - CMX702.
Here's the link: http://www.partsamerica.com/PartDeta...pe=219&PTSet=A
If that doesn't work just go to www.advanceautoparts.com and go through the menu on brake pads.
Old Feb 27, 2004 | 05:10 AM
  #321
cloud10's Avatar
cloud10
brake dust
thanks mrslate i checked out your link thank you!!!
Old Feb 27, 2004 | 05:30 AM
  #322
cloud10's Avatar
cloud10
after reviewing all comments in here about the brake dust problem on the expeditions my conclusion is that i beleive the factory brakes are the best choice they were engineered for this vehichle no no doubt provide the best stopping ability of any pads available----yes i know there is a terrible problem with the brake dust you all know that of course as i do and that the wheels and tires and the front of the running boards become a mess and need a time consuming scrubbing everyday or two and that it takes 30 miniutes a wheel with all the right wheel brushes i hate it as much as u all do mabe more im a natual born slob but by gosh im a clean freak when it comes to vehicles. i talked with several folks here by brother in law who is employed by gm tells my that gm brakes are dirty too and the factory isnt concerned with it and i talked with my friend who owns a detail shop here and says he uses the kleen wheels and has had for a few years and that they work really well he did tell me that on occassion they will rub the calaper and if this happens you will see where the rough spot on the caliper is and to just smooth it with a dremel. so in closing i think i will continue to use the factory ford brakes and install the kleen wheels dust shield.
Old Feb 27, 2004 | 05:50 AM
  #323
sdavid's Avatar
sdavid
Thumbs up no more brake dust problems
my local ford repalced mine with the new brake pads and WOW!!!!!!
its been 1 week and the wheels still look great. and the best is it was FREE...........................................
2003 EB EXP
3000 miles
Old Feb 27, 2004 | 06:07 AM
  #324
ExpyBob's Avatar
ExpyBob
Well I agree with cloud10's post.
As I have said many times on different boards, for $70 I use the Kleen Wheels and they work great. There is no dust---period. The rubbing of the caliber someone mentioned is an indication that they are not installed properly. They should be placed in the wheel first then the wheel mounted to the truck.
I have them on all four wheels. When I do need breaks, due to wear, I will replace them with Ford replacements of the time and still keep the Kleen Wheels.
Oh, my dealer installed them for me for free during a tire rotation. He actually recommends them and they have put them on Expys and Navs.
For those that have gotten the new pads for free, or otherwise, there will still be some dust. I have none.
Bob
Old Feb 27, 2004 | 06:09 AM
  #325
cloud10's Avatar
cloud10
thanks sdavid i talked the local ford store here they tell me that repalcement pad are not covered under waranty which is ahame i have puchased a new 03 expedition in feb of 03 and traded it on an 04 expedition in dec 03 i would say that i guess i havent spent enough at ford yet to get the red carpet treatment lol
Old Feb 27, 2004 | 06:19 AM
  #326
cloud10's Avatar
cloud10
thanks expybob after getting your reply i feel much better about my choice to use the kleen wheels dust sheilds this is exactly what i want NO DIRTY WHEELS PERIOD!!!!! my friend at the detail shop loves them. once again folks use caution in changing your pads the factory ones dirty as they may be were engineered for your expedition to stop on a dime,9 cents change. theses are 7300 lb gwrv vehicles they need to stop!!!!
Old Feb 27, 2004 | 06:35 AM
  #327
cloud10's Avatar
cloud10
expybob that was i who made the comment about the calapers rubbing what i meant was that the detail guy who installs these told me that while most of the time there is no rubbing and yes they can be installed improperly-- all he was saying is that ocassionally there can be some casting rough spots on the calapers that may rub even on a proper installation and that you will see on the back side of the kleen wheel dust shield where that rough casting slage (which should have been trimmed at the manufactuer) is rubbing needs to be dremmel tooled off. he says its uncommon but does happen. my luck ill be the one that needs trimmed. thanks expybob its good to know someone having such great results with this product its my choice too!! NO MORE DUST, YES!!!!
Old Feb 27, 2004 | 09:12 AM
  #328
raudy's Avatar
raudy
Here are the ceramic pads I bought, but still have not got them on my 04, hopefully this weekend.
TRW Ceramic F Exped/NAV 2003, part #16-934-12, bought on line from Philsinc.com, cost with shipping for two fronts 62.66.
For 04 owners makes me really mad, mine was built 11/03, I read 12/03 the 04's had the new pads...
Old Feb 27, 2004 | 09:24 AM
  #329
cloud10's Avatar
cloud10
thanks raudy i appreaciate the response hope your new pads work well for u. thanks!!!
Old Feb 28, 2004 | 10:32 AM
  #330
cloud10's Avatar
cloud10
got the kleen wheels ordered future posts to follow
