03+ - Brake Dust Update
Old Feb 15, 2004 | 08:13 PM
  #286
Zoombah's Avatar
Zoombah
Sorry. Didn't read all the posts before posting this reply.
Fixed my dusting headaches by going to ceramic pads. Cost $80 just for front pads but now get virtually no dust and no squeaks. Had the pads probably 3 years now. This was not a new vehicle warranty situation, but even if it was I might have been inclined to spend the $80 just to get rid of the annoyance.
Old Feb 17, 2004 | 09:45 AM
  #287
alphascrew's Avatar
alphascrew
My Expedition was in yesterday to have the new brake pads installed.
My dealer installed front and rear pads, 3000 mile scheduled maintenance, brand new rotors front and rear...all at no charge!
For the first time I feel that I have a new car!! I had 2 issues...the brakes and front drivers door squeak!
Both have been fixed!
Still a little frustrated with how Ford has treated this, but very pleased how my dealer has once again earned my loyalty to his dealership
Old Feb 17, 2004 | 09:51 AM
  #288
daveplot's Avatar
daveplot
alpha... do you know how they fixed the door squeak? My front passenger rattles and they have changed the door latch and weather stripping with no success.
Old Feb 17, 2004 | 11:36 AM
  #289
alphascrew's Avatar
alphascrew
They replaced the window seal...that didn't work...then they replaced the body seal...that didn't work...then they replaced the latch...that didn't work...then I took them for a ride to make sure we were both hearing the same thing...they then re aligned the door by 1/16" and the squeak was gone..not completely but acceptable..
It lasted about 3 weeks and then the squeak gradually came back..
I was going to have them look at it again yesterday when they did the brakes, but I decided to post a description of my squeak and Expybob advised me on how he fixed his squeak..
Here is his reply to my post:
I have a 2004 with the same thing. The door is perfectly aligned with the rest of the body so I am hesitant to have it messed with.
If you notice the harder plastic gasket that runs on the outside of the soft inner one has rub marks on it. When you drive and stick your finger tips in the top crack of the door on the inside you will feel it move.
I put a light coating of silicon grease on both gaskets on the top and windshield side of the gasket and it's never come back. That was about 2 months ago.
Hope this helps--Bob
I applied wd-40 on all the seals on my drivers door and the squeak went away...EXPYBOB has advised me not to use WD 40 as it will dry out the seals..I will use silicon this weekend...It appears that the size and weight of the vehicle there will be a certain level of stress and movement..so if the seals are lubed up it should be able to move noise free...makes sense to me...regardless the noise is gone and I will be lubing up all the seals with silicon as I am beginning to hear on develop on the rear hatch...
Hope this clears up your squeak...
Old Feb 17, 2004 | 04:02 PM
  #290
Vernon_04_Expy's Avatar
Vernon_04_Expy
Is the door rattle the same as the window rattle? That is what mine is doing seems like the window rattles (drivers side). Becuase they also replaced the window run (seal) in miine and of course no joy. I'm thinking I should put the silicon in between the seal that the window rolls up into. Or am I totally way off and I have a whole different problem?
Old Feb 18, 2004 | 07:34 PM
  #291
mechdeclined's Avatar
mechdeclined
Just got my 03 expy back from dealer. they replaced all four brake pads under warranty. TSB #04-1-1. Will let you know if it makes a difference. I also had a rattle in my door at highway speeds NOT when going over bumps. They replaced the latch assembly and weatherstripping under SSM 17078. We'll see if it fixes problem.
Old Feb 18, 2004 | 07:40 PM
  #292
spjlj1's Avatar
spjlj1
Do you have the detail of TSB #04-1-1?
Old Feb 18, 2004 | 07:46 PM
  #293
daveplot's Avatar
daveplot
the TSB is back a few pages in this thread.
Old Feb 18, 2004 | 10:20 PM
  #294
alphascrew's Avatar
alphascrew
I want to give everyone an update on the new pads...It has been 3 full days of driving and there is noticable brake dust on the front rims..rears are not too bad...
Comparing the amount of dust to the aftermarket pads, I would say more than double...the amount of dust that there is on the rims now took the aftermarket pads over a week to produce.
If I paid for these pads I would be screaming at my dealer right now...
I will ride it out...I don't have the energy to go back to the dealer or spend any money at this point for aftermarket pads...
I will wait for the RAYBESTOS pads and replace them in a year..
Very dissapointing FORD!!!
Old Feb 19, 2004 | 10:49 AM
  #295
raudy's Avatar
raudy
AlphaScrew, that is disappointing for sure. I wonder if I should put the 3rd party ones on my 04.
I did call Ford yesterday and they said since I have an 04 I may qualify for Ford replacing them under warranty at no cost. They wanted my vin to run through OASIS, whatever that is. HE did say they were on back order so did not know when they would be available.
But now I am not sure if I want the Ford pads based on what you wrote. Maybe should have my son put those aftermarket pads on that I just bought.
Decisions.....
But now I am not sure what to do after reading your post
Old Feb 19, 2004 | 11:19 AM
  #296
alphascrew's Avatar
alphascrew
Again...it's only been 3 days..
The dealer didn't give me a receipt or copy of the work order..
I wil call them today to have them fax me a copy..I'm wondering if the technician put the original pads on...they did that once already..
I will confirm and let you know...
Old Feb 19, 2004 | 11:56 AM
  #297
raudy's Avatar
raudy
alphascrew - that makes more sense to me, if the new pads are so UNAVAILABLE, they may have screwed up and put the old pads on. There was someone on this forum who got the new Ford pads and said they were great. Honestly, twice they messed you up, go figure.
Old Feb 19, 2004 | 01:00 PM
  #298
Dwights's Avatar
Dwights
alphascre, my new Ford pads are dust free so far. BIG, Big difference !!!
Old Feb 19, 2004 | 01:30 PM
  #299
alphascrew's Avatar
alphascrew
I don't doubt it..I think they put the originals..I'll know shortly...
Old Feb 19, 2004 | 02:18 PM
  #300
alphascrew's Avatar
alphascrew
I got a copy of the invoice...
4L1Z*2001*AC KIT-BRK SHU & LNG FRT is what was installed...It appears to be the new pads...maybe the dust is from the new install???
I'm wondering if there is a break in period for the new pads??
