- Easy way to make your FE a dog or atleast mine
- bought a cam, hope its ok
- 360 FE identification?
- Which oil is best for a 390?
- new engine problems
- i hate electronics..........
- duraspark distributor in a older motor
- 390 Oil Pressure problem (less than 5 at hot idle)
- One Digit Mileage!?!
- T19 Trans
- Headers!
- Latest on the 511 project...
- jumpin the gun
- Gtex, now that you are back, a question...
- What'd I miss?
- Use unleaded gas in 390?
- Which lines are these?
- performance upgrade question
- 1965 t-bird 390, how much horsepower?
- Install ARP Oil Pump Shaft
- what do you guys think?
- Hey G !!!
- 360 Transformation
- What's proper "stock" timing?
- motorcraft or holley
- Updated spring recommendations for Crane cams!
- Cylinder to water jacket clearance
- casting numbers on block and crank
- where do you fined the casting numbers on the block
- coolant in #4 cyl
