- Thank you Lariat 85
- Flareside diamond plate protector progress
- Freeze plug
- Transfer case/ transmission mount
- Parts from 79 351m to 85 351w Duraspark Conversion
- Heater core
- Gary Lewis
- Ignition cylinder issues
- Back fire
- Is it my valve body
- Header in stalling issues
- 1983 parts are starting to disappear
- 80-84 Tailgate Letter Attachment
- Anybody want an outside mirror?
- Stalling at idle, and idle surging help.
- Radio bezel question
- Headliner drooping, how to fix?
- Wood fire smell, now only high speed blower
- I6 4.9 intake/exhaust bolt set
- Rear drum brakes/ parking brake issues
- Loose mirror
- heater vac lines
- Replaced wheel bearings and ball joints recently, pictures and experiences
- Factory fuel line and connections
- 1983 F150 5.8L Heating Core
- A/c & heat direction select switch
- Does 83 F100 have an electric fuel pump?
- How to put redline paint back on ralley trim rings
- How to lube clutch linkage?
- Cruising RPMs
