Ignition cylinder issues
Old Nov 22, 2017 | 03:41 PM
Gigemags05's Avatar
Gigemags05
I am installing a NON tilt column from an 82 f150 into my truck and am going to replace the ignition cylinder before I do it. When I tried to remove the cylinder, I realized it was very hard to turn, and then when I pressed the pin down to remove it, I couldn't get it out. Upon further review, I the rod that connects to the ignition switch barely moves when I do get the ignition cylinder to turn. Any ideas what I need to do? I googled the issue and the only hits I get are for tilt columns.
The rod, even when the ignition cylinder is in lock position, is well below the surface of the hole where it usually protrudes a good 1/4" or so. (not sure if that makes any sense or not.) Its like turning the cylinder isn't engaging the rod or actuator.
Old Nov 22, 2017 | 04:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Parts catalog pic: 11582 is the cylinder .. 3C610 is the snap ring that retains it .. 3E700 is the flat 'bearing' .. 3E717 is the brass gear.
11A599 rod is shown next to the 3530 shroud.
Old Nov 22, 2017 | 05:16 PM
Gigemags05's Avatar
Gigemags05
Ok thanks. If i can figure out what the issue is i will definitely need those part no.s i don’t have that blow up.
I cant figure out what is not operating appropriately, and am not sure how to begin.
TexanAmmo
46
Dec 17, 2016 01:21 PM
Toplait
Apr 27, 2015 07:30 AM
stil190
Mar 21, 2015 07:05 AM
Blitzcraig
Mar 5, 2012 10:45 PM
i-w
Dec 4, 2009 01:50 PM
