Loose mirror
Old Nov 19, 2017 | 02:12 PM
petritl's Avatar
petritl
Loose mirror
The mirror was stuck so I oiled the little ball joint and now the joint is loose. Is the a way to tighten the joint?
Old Nov 19, 2017 | 02:15 PM
petritl's Avatar
petritl
Old Nov 19, 2017 | 05:57 PM
James Wagoner's Avatar
James Wagoner
I had that same problem with mine. Nothing I could do. Replacing it was my only option. Got the bonus of new shiny mirrors.
Got mine from LMC but you can probably find a pair at auto parts stores.
Can look at my album photos to see the results.
Old Nov 20, 2017 | 04:21 PM
401tonyo's Avatar
401tonyo
Try tightening the two screws on the bottom,worked for me.
Old Nov 20, 2017 | 06:10 PM
Nothing Special's Avatar
Nothing Special
If you had factory mirrors, then no, nothing you can do. Then again, if you had factory mirrors you probably wouldn't need to.
With aftermarket mirrors like those, the two screws will tighten it up. And then it'll loosen up again and you can retighten the screws again. And again. And again.
The only downside to factory mirrors is they're stinking expensive. I paid a dealer $300 for a pair of new ones for my '97. It stung a lot at the time, but I sure love having mirrors that stay where they're pointed and don't vibrate.
Old Nov 20, 2017 | 06:41 PM
Franklin2's Avatar
Franklin2
Take the nut off, take the mirror off and tighten those two phillips screws on either side of the ball. Then re-install it.
Old Nov 21, 2017 | 02:22 PM
1986F150six's Avatar
1986F150six
Since adding lubricant caused the mirror to be too loose, why not try spraying the same area with brake cleaner and see if it is better?
Old Nov 23, 2017 | 02:25 PM
petritl's Avatar
petritl
the screws tightened and the mirror seems to be better but soon began to move around while driving again.
Thank You for the advice
Old Nov 25, 2017 | 09:43 AM
DeereFord300's Avatar
DeereFord300
Would a bit of loctite on the ball work?
Old May 4, 2019 | 10:31 AM
RenoHuskerDu's Avatar
RenoHuskerDu
Try putting some urine or DEF on that little ball, and let it sit.
Old May 5, 2019 | 03:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The mirror head came with the mirror, but it was also available by itself.
EOTZ-17723-A .. 6" x 9" Mirror Head - Use with TYPE 9 Low Mount Swing-Lock Mirror - Single Position - Stainless / Obsolete
1980/91 F100/350, Bronco & Econoline; 1988/91 F(Super Duty).
TIM SHORT FORD in Hazard KY has 1 = 606-436-5239.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
KAMA OBSOLETE PARTS in East Bethel MN has 1 = 763-434-0123.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
Lower pic:
Old May 5, 2019 | 09:10 PM
RenoHuskerDu
We tried putting some DEF on that little ball, and let it sit. No better.
We tried dimpling that little ball with one of my good small center punches. It dulled the point! WTHeck do they make that little ball out of???
Tonight we wrapped a small cotton strip around that little ball and soaked it in DEF. Tomorrow hopefully its smooth surface will have been attacked by the urea in the DEF.
Will report back....
edzakory
Feb 8, 2018 02:21 PM
tomtoc
Aug 2, 2007 06:53 PM
backhoeken
Appearance & Dress-Up
Sep 12, 2005 06:55 PM
joners
Jun 18, 2004 12:23 PM
