- swap SOHC for OHV motor
- Which Code Reader To Buy
- 99 explorer transmission
- 4.0 rear timing chain access
- Bad Gas?!?!
- Can't remove lower ball joint 2000 Explorer
- AWD front driveshaft
- ford explore cruise control recall
- leaking moon roof
- Adrenaline grill
- short in electrical system 1992 explorer
- Class II to Class III
- 94 Ford Explorer 4x4
- Plastic fender flares
- door lock actuator
- Question about vibration
- Rear Toe Link 02' Explorer
- replacement running boards
- Adding Tranny drain plug kit - which one?
- 04 explorer blend door
- 2000 Explorer 4x4 driveline vibration
- changing fuel filter
- fuel pump starting to..
- fuel filter
- Heater core replacement?
- tranny
- ABS Brake light on
- CobraXP...Some Questions...
- Alarm won't shut up and has a mind of it's own!
- 4 wheel drive problem
