PDA
View Full Version : Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Piston 312
  2. 292 no oil to Rockers
  3. Missing the Lope.
  4. 1956 292
  5. 1955 Ford truck
  6. crack in the block
  7. Where's The Lincoln Y-Block Guys At ???
  8. 292 solid lifter breakage
  9. What is the CFM?
  10. fuel delivery issue....help please!!
  11. OK, so now the timing is right how much torque do I have?
  12. need help with a power valve replacement
  13. correct ignition adavance
  14. '55 239 problems
  15. Need Advice On Building Motor
  16. how do I remove front motor mount?
  17. Value
  18. carb/intake manifolds
  19. Head removal, HELP!!
  20. 292 Crankshaft Pulley/Damper
  21. fuel pump for 262
  22. Are all Y dipsticks & tubes the same?
  23. Y Block 292 fuel injection conversion
  24. propper petronix
  25. Y-Block Intake Manifolds
  26. Anyone looking for a Y block?
  27. Jahns 312 y-block pistons? need help to ID
  28. street rodder
  29. replacing rings
  30. Rockers still making lots of racket (video)
