need help with a power valve replacement
Thanks for your help
well it is difficult to tell without know exactly which carb you have.
Go HERE for an exploded view of a Holley 2300 series 2 bbl carb. The power valve is #45 in the illustration.
Here's a 2010 series too...
If that's not the one you have you can probably search around for it on the Holley site.
Regards,
Rick
the exploded view is great! I do have a 2300 series. I'm probably missing something very obvious, but when I take the fuel bowl assembly off the front, what is holding the metering body on? I'm I approaching this wrong? I'm trying to get to the power valve from the front, do I need to take the carb off? This is my first venture into a carburator so I'm flying blind. Wanted to get this done today and local auto parts store is closed today so I can't get a book on Holleys.
Thanks again for your help
most likely the gasket.... they get 'stuck' to the surfaces..
[can Be Tight Fine Threaded Be Care Full To Use A Good Quality Open End Wrench Secured With Pressure Then Strike Down C.c.with Mallet /can Be Very Tight /or Use Good Thin Wall Socket If You Can Get Into It /its The Impact The Doe's It /check Spring +plunger For Damage/weakness [ And On Metering Block +gasket Small Bypass Hole On The Edge That It Aligns Correctly Or It Will Restrict Flow Through The Block [ The Holes Use To Be Rectangular In The 70's I Told Them Some Improperly Aligned And Designed Caused Flow Restriction So They Started To Cut Them Oval Pattern Much In Proved Good Basics Will Pay Off Hope This Helps Ps. Nice Holly Site Advice Guys
