- Comparable flow rates of 3 common Y heads
- Dummy with a Master Plan - Need advice
- Powder Coating Engine Parts
- Distributor
- will 292 mount up to 3speed trans 56 f100
- 59 coming soon
- 272 that has outside rocker oilers now change or not
- 54 256 water pump
- 292 Oil Pump Pickup Tube
- new to Y-blocks
- Y-block engine ID
- 292 performance
- 13-tooth, 14-tooth?
- 332 Truck
- heads
- Toploader Four-Speed?
- Got a line on a 312
- Oils well ends well - I hope
- Has anyone put a FE engine in a 292 truck??
- Will theese work
- heads
- Load-O-Matic replacement
- Points to electronic distributor info needed
- oil pressure
- Pictures or links to pictures of Ramhorn Manifolds for Y-blocks
- Oil passage blockage
- overall dims for a 59
- temp sender bushing
- tommorrow is D-day
- I Need a 292 Block Help!!!!!
