PDA
View Full Version : Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 272 Valve Adjustment Help
  2. 1956 312?
  3. 57 312 Y-Block with Holley Carbs- Deadspot
  4. Got another Y going.
  5. flywheel cover is missing
  6. Ford vs. Mercury any difference?
  7. Y block Bellhousing question
  8. 292 timing
  9. very high idle
  10. 292 c1te
  11. 272 oil leak fix help
  12. 239 dumps oil
  13. 312 oil pumping on 1 side of motor
  14. 292 oil pressure
  15. 292 just rebuilt seapage
  16. Mustang Transmission fitted to Y-Block
  17. need help hooking up linkage to 4100
  18. found a funny heaven
  19. Manifold Vacuum on a 292
  20. opinions please,
  21. Bellcrank or not?
  22. Anyone know how to convert Y block distributor to Duraspark?
  23. Carb in Question
  24. Heat Riser Tube Repair???
  25. Torquing Sequence
  26. 312 y-block on criagslist
  27. 6 Blade Fan
  28. help with tranny id
  29. Vacuum gauge
  30. Float sticking open
