PDA
View Full Version : Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. ARP Rod Bolts
  2. please lend your opinion
  3. 292/Ford-O-Matic
  4. Upgrading 292
  5. New truck - First Y Block - questions
  6. Can I save my 400?
  7. intake manifold gaskets
  8. Camshaft ID help
  9. Rocker arm interference
  10. Loose push rod? new to Y blocks
  11. Rocker Arm Shaft MOD???
  12. Dampner center bolt torque spec
  13. Y-block aluminum heads
  14. Looks like a leaky head gasket - - Safe to Drive
  15. Timing Pointer missing
  16. Timing Pointer missing
  17. double heas gaskets
  18. Starting 292
  19. Damper & Pulley replacement '59 292 Y-block
  20. Crankshaft regrind
  21. Block ID B9AF 6075
  22. 292 bearing clearances
  23. Cam choices...
  24. Y-block vs SBF
  25. Distributor Lobes - Question
  26. Exhaust in coolant
  27. Question 6v Starter on 12v system
  28. 1956 F 100 stock 272 distributor
  29. Help! Identify these heads!
  30. Water/oil leak
