replacing rings
Old Jul 21, 2008 | 04:17 PM
newbyyhead03's Avatar
newbyyhead03
replacing rings
whats the easiest and cheapest way to replace rings in a 292 f-100. i have a lot of blowby and think my rings have cracked
Old Jul 25, 2008 | 09:55 PM
flipklos's Avatar
flipklos
Buy rings and install them. youll need a complete gasket kit.
best to spec out your bores and have your heads ground while your in there.
Old Aug 29, 2008 | 12:42 AM
JasonCorvallis's Avatar
JasonCorvallis
Do NOT tear into your engine for just that purpose. you will find broken pistons bad cam bearings cylinder walls tapered timing chain deflection out.
once you go in plan on a big repair. plus if its factory you need to install the hardened valve seats with an aftermarket overhead oiling system. Unless you plan on doing a complete rebuilt seriously think about wether you want to open that can of worms.
Old Aug 30, 2008 | 12:08 AM
46yblock's Avatar
46yblock
I completely agree with the first paragraph. As for hardened seats not so much, unless the truck is going to be worked frequently or run on the strip, or there is an aftermarket cam requiring high spring pressures. Also do not agree with the need for overhead oiler. Opening a can of worms...absolutely. The last and recent 292 I tore down was a "runner". Timing chain had so much slack it may have been hitting cover. Bearings bad, crank needs reground, lifters were concave on the face, multiple broken rings, cylinder taper BIG, distributor centrifugal weights close to breaking at the spring anchors, and so on.
Yes, if you need new rings there are many more things needed too.
IDMooseMan
21
Jul 29, 2017 01:32 PM
skidoorulz
Nov 1, 2015 06:21 PM
skytop19177
Jun 23, 2015 05:09 PM
HT32BSX115
Sep 30, 2014 05:50 AM
clint stafford
Aug 28, 2014 06:41 AM
