PDA
View Full Version : Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88
  1. How do I prep the old engine for the 1st Start
  2. gettin started
  3. cross over pipe
  4. Were is the enigine number?
  5. Exhaust manifolds
  6. Road draft to PCV conversion?
  7. Y-block bellhousing question - same as 221/260/early 289?
  8. exhaust question...
  9. C4 to Y block in a 54
  10. Head gaskets on 292
  11. Carb Replacement
  12. ramshorn exhaust manifold
  13. 292 oil light/gauge sender plumbing input needed.
  14. Blown head gasket - need help with ID
  15. 292 Y Block Fuel Pump
  16. valve clearence
  17. Stromburg 97
  18. Janets Alternator for Yblock 292,272,312 setup information,for Ray and others
  19. 292 Considered bad Motor?
  20. What do I do with my extra 292 engine and parts?
  21. Header installation
  22. 292 generator swap
  23. 239 Y-Block
  24. 292 Rebuild
  25. Changing cam and lifters in 292
  26. 59 Edsel 292
  27. My 1955 Ford 1/2 Ton PU,,,,,Engine Question Please!!!
  28. runs good til warm
  29. What kind of Carb is everyone using and how do you like it ?
  30. hiya folks 63 f 100 here
