- Are EBU-A and C2AE the same type of forgings
- Mahining costs over there??
- Water pump pulley
- Explain please this crank in a virgin 292
- Distributor Identification
- Engine will not run unless choked
- Flex Plate And Crank Dampener Update
- Yblock Motor Mount question - TH700R4 related
- Converting 6 Volt Distributor To 12 Volts
- Engine Block Casting Number
- Does Pertronix make a module for a 55 239 ?
- Manual On CD/DVD
- Intake Manifold Casting Number
- Cruisomatic Have A Vacuum Modulator?
- Number Dummy
- Cruisomatic Bellhousing To Toploader Transmission
- 332 parts
- pushrod length double take.
- anyone know torque spec's for 11 clutch pressure plate??(nm)
- Need a valve rotator and some ideas.
- y block horsepower
- Totally stumped...
- what size y block in 54 merc.
- Engine Number ?
- fuel pump eccentric counter weight
- Crossover Exhaust Taken Apart
- Cylinder Head Question
- Autolite 2100
- Flex Plate Bolts Question
- Next step
