390 A/C Brackets
Old Nov 22, 2001 | 02:04 AM
arusj's Avatar
arusj
390 A/C Brackets
I've got a '76 F-150 with a 2V 390. The truck didn't come with a compressor or the A/C brackets. We got a set of brackets out of another '76. This compressor mounts vertically. The lower bracket # is D3TA 2882 AA. My original, guessing by the hose lengths, mounted horizontally. I know this makes no real difference, but the problem I have is getting the A/C adjustment idler and the compressor pulley to line up with the water pump, crank and lower idler pulleys. They both sit too far back from the other three. I thought I could get away with it, but I took the truck to the landfill last weekend and threw the belt when the A/C was off. So tonight I fooled with that pain in the rear for hours trying to use combinations of spacers to get the compressor lined up. This caused a few problems, the lower idler then doesn't line up, things are not straight, and the power steering pump is off. So on to my questions: First, will the dual pulley clutch fix this? If it will, where in America can I find one? I've had no luck to speak of. Second, how many different bracket sets did Ford make? Third, I am thinking of welding some new ones. The lower bracket is 5/16" forged steel and all I have is 1/4" plate. Will that be heavy enough?
Old Nov 22, 2001 | 05:39 AM
jowilker's Avatar
jowilker
390 A/C Brackets
You probably need a new crank pully just for the AC.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Nov 22, 2001 | 04:54 PM
arusj's Avatar
arusj
390 A/C Brackets
I just decided to make new brackets. I have it accurate within 1/64" Thanks for the advice.
Old Nov 23, 2001 | 11:30 PM
jbhf250's Avatar
jbhf250
390 A/C Brackets
Scotty's 52 F3
17
Apr 16, 2025 10:18 PM
1972RedNeck
Apr 8, 2016 10:50 PM
MadMatt65
1978 - 1996 Big Bronco
Aug 16, 2013 08:45 PM
tfmech
Jul 14, 2012 11:54 AM
460Runner
Aug 21, 2011 09:48 PM
