intakes
Old Nov 21, 2001 | 01:53 PM
nitrous125's Avatar
nitrous125
intakes
Howdy all I am wondering is the Blue Thunder or Edelbrock RPM better for my 390. It has a brand new bottem end around 9:1 compression a crower power beast cam, msd ignition, holley 600cfm vacume secondaries carb. And soon to have a 4.11 rear. Which intake would be best for my setup.
Old Nov 21, 2001 | 03:25 PM
FE427TP's Avatar
FE427TP
intakes
Everyone I've heard who has used them said they are very similar, if you plan on using the full RPM range they allow you will probably want/need a bigger carb anyways.
Old Nov 21, 2001 | 05:46 PM
FEina52F1's Avatar
FEina52F1
intakes
Is the Blue Thunder a dual or single plane ?
Does anyone know how many (what are they ? who makes them) intake manifolds are currently available new for FE's
(anyone got url's to pics ?)
Old Nov 21, 2001 | 05:48 PM
nitrous125's Avatar
nitrous125
intakes
howdy man the carb is set up for this truck we had a 750 and it didnt have as much gett up and go. So we bolted on the holley it has now. We jetted it from an engine dyno. The truck is making 410hp and 396foot pounds of torque. It has a ole holley intake on it now but i wont to upgrade. So i was just wondering.
Old Nov 21, 2001 | 07:50 PM
FE427TP's Avatar
FE427TP
intakes
>was just wondering.
Can you tell me a bit more about your combination, What head castings do you have? standard or CJ valves? What intake are you currently running? As far as FEina52F1's post the ones I know of are....
Dove: approximately 22 manifolds... (from an old ad in a magazine I have, I'll try to post it soon)
Carrol Shelby: 2 ( http://www.carrollshelbyent.com/engine_parts_services.cfm )
Edelbrock: Performer and Perf RPM
Weiand: Single plane
Offy: 5 (portosonic {rare, lots of backorders}, 360 degree equaflow {kinda crappy in my opinion after looking up the ports} and I believe a 2 4v lowriser intake and then the dual port one, and a like "classic" one)
http://www.holley.com/HiOctn/ProdLine/Products/AMS/AMSM/7282.html )
Blue Thunder: 7 (428 CJ H/R 4V manifold (two versions) 428 CJ H/R Dominator manifold 427 medium riser H/R 4V manifold (two versions) 427 medium riser H/R Dominator manifold 390/427/428 6.71 blower manifold)
Don Hampton Blowers also has a blower manifold based off of the old Holman Moody but slightly revised unless it's just cast by blue thunder ( http://www.hamptonblowers.com/PRICE.HTML )
Old Nov 21, 2001 | 08:29 PM
FE427TP's Avatar
FE427TP
intakes
Old Nov 21, 2001 | 11:51 PM
FEina52F1's Avatar
FEina52F1
intakes
Is it actually posible to obtain anything from Dove.
I've had a parts supplier I used to work for fax and phone a few times not much response, and heard bad things.
I have one of these poor excuses - good foundation for a blower though
>Offy: 5 (portosonic
dreaming of owning one of those
single or dual plane ??
>Offy: dual port one,
I have one of theses this is an even a poorer excuse
that is the weiand - yuk
are any of these single plane ?
thanx
Old Nov 22, 2001 | 02:35 AM
FE427TP's Avatar
FE427TP
intakes
They have had porosity problem, George at Gessford found a way around that by sealing the intake using a process that sucks a resin or something into where there is porosity. As far as hearing bad things. I'm convinced that it's a good intake if you have the engine for it. I talked to someone once who said he picked up 9mph in the 1/4 with putting the dove single plane on his engine. enough convincing for me...
>>Offy: 5 (portosonic
I've heard it's so so unless you port it then it's pretty good, but is beat by the dove hands down if you have the engine for it.
The picture of it that I have is for a BBC but it's single plane for that. and it only takes Carter carbs
I dont know, that's the info I got right off their site, you could try E-mailing Rob McQ at Blue Oval Performance he deals in blue thunder stuff and should know.
Old Nov 22, 2001 | 09:18 AM
Fatz's Avatar
Fatz
intakes
cryptospook
1997 - 2003 F150
19
Sep 1, 2016 11:45 AM
wills 64
Jun 26, 2015 03:50 AM
new7.3owner
Jun 24, 2014 06:34 PM
75boogieman
Apr 11, 2013 05:10 PM
robertspangler
Feb 11, 2010 09:49 AM
