soon I will have to remove my intake to stop a leak. I have read a few things on here about some people blocking off the exhaust cross over in the intake to obtain a cooler air charge.
what is the best way to do this. how much difference will the cooler air charge make?
I blocked mine off because of the CR and wanting to prevent pinging, with a colder intake charge you can run a higher CR and more advance without pinging and every little bit helps, but it really depends on the engine, for a stock setup you see little to very little change. If your in a colder area you might want to pass on this.
I used a product called quick steel, it's simular to JB Weld but holds a bit more temp. I like the idea of an old kitchen knive, cheap and effective.
If you want to make a noticeable difference, draw cold air from the side of the rad to the air cleaner (I've found several stock setups at the junk yards), then block off the crossover and adjust the timming for max adv without pinging under load.
>If you have a cast iron intake, don't do it. Your
>drivability will suffer.
why is this?? I do have a cast iron 4-v intake(cast # C3AE9425B). I have alwys heard that a cooler charge is better.
I know that cooler air is denser and therefor results in a better air-fuel mixture. I know a fellow who races super late models on dirt track and he puts ice in his air intake to acheive a cooler air charge.
I live in Tennessee so winters aren't to bad here and I have a manual choke carb.
just wandering why this isn't a good idea for a cast iron intake?
Street driving and racing are two different things (at least they should be). Blocking off the crossover will make your engine cold-blooded and drivability will suffer. Iron conducts heat slower than aluminum so a cold iron manifold takes longer to warm up. When vaporized fuel hits the cold manifold it condenses and puddles out into liquid, especially on the floor. That’s why those ribs are down there, more surface area like a radiator. The unvaporized fuel just washes off what little oil there is on the cylinder walls and then goes in the crankcase. Also, factory iron manifolds usually don’t have very good fuel distribution to begin with so the heat helps here too by keeping whatever fuel you have in suspension. There are exceptions to this like the “S” manifold, it has pretty good distribution.
I'm gonna have to dig up some old hot rod books that explained this much better.
If you climate is mild you can probably get away with it but if it gets cold and damp, your carb. will ice up.
I’ve heard a good compromise is to block one side only.
