Piston pin bushing question
Old Jul 24, 2009 | 08:25 PM
stsavoie's Avatar
stsavoie
i was removing the rods from the pistons on my 360 when i noticed one of the piston pins spun in the rod and pulled out a little bit. i tried to push it back in but all i did was ruin the bushing. i was wondering if anyone has installed new pin bushings and if so how did you do it??? is this something that should be left to a machine shop or can it even be done by the average guy??? thanks
Old Jul 24, 2009 | 09:43 PM
Redmanbob's Avatar
Redmanbob
machine shop, needs to be pressed, oil hole fit, then reamed to fit the pin. 35.00 ? maybe for 1 ?
Old Jul 25, 2009 | 01:57 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Um, I don't understand how you ruined the bushing pulling the rods from the pistons. They aren't a press fit.
Old Jul 25, 2009 | 04:58 PM
stsavoie's Avatar
stsavoie
the pin had some varnish or oil residue on it and when i pulled the pin out it pulled the bushing out too
