Drop pitman arms???
Old Jun 19, 2005 | 01:44 AM
greybullit's Avatar
greybullit
Drop pitman arms???
Does anyone make a drop pitman arm for a 75 F250??? Anybody know or should I just go with th x-over steering??? and if I do that, will x-over steering work with any size lift or do I have to make it specific to my lift height? and then....how would I do that??? Thanks for all the help.
Old Jun 19, 2005 | 02:03 AM
ivanribic's Avatar
ivanribic
I can't find one available but I'll tell you that the drop pitman I'm using on my 78 is for an F150 and it fits just fine. If you check my gallery I have some details on crossover steering systems there. It does basically need to be made for your truck, dependent on height, etc but it is easy to do and adjustments can be made to lengthen or shorten it if you use tie rod ends.
Old Jun 19, 2005 | 02:47 AM
greybullit's Avatar
greybullit
right on, thanks alot
