chassis lengths
Old Jun 21, 2005 | 02:25 AM
rhenson1's Avatar
rhenson1
chassis lengths
i have a 79 2wd supercab shortbed with a 460 and c-6. I was wanting to know if the body would bolt on a 4x4 regular cab long bed frame. would you have to move mounts or is it just impossible thanks ron
Old Jun 21, 2005 | 02:27 AM
ford390gashog's Avatar
ford390gashog
i think it will as long as you use a short bed.
Old Jun 21, 2005 | 12:16 PM
rhenson1's Avatar
rhenson1
yeah i would use my short bed. thats what i want to see if i can do. put a supercab shortbed on a regular cab longbed frame
Old Jun 22, 2005 | 11:07 PM
IAM.CA's Avatar
IAM.CA
Check what your wheel base is on your truck. A reg cab/long box is a 133" wheel base. Another thing to consider is that the frame rises once it passes the cab. So even if the wheel base is the same (although I think the supercab wheel base is somehwere in the 138" area), the frame on the 4x4 chassis will be rising in the back portion of the supercab. It could be done, but a lot of fabbing will be neccesary.
Old Jun 23, 2005 | 08:28 PM
fatherdoug's Avatar
fatherdoug
A short-bed supercab has a wheelbase of 138.8 or 139", depending on whether or not it is an F-100 or F-150. The long bed conventional cab has a wheelbase of 133".
Old Jun 24, 2005 | 12:52 AM
ford390gashog
my supercab short bed has a 133'' wheel base.
Old Jun 24, 2005 | 01:40 AM
rhenson1's Avatar
rhenson1
thanks guys for the info. since i wrote the post, a guy at work measured his reg cab long bed and came up with the same numbers. i guess i will continue to search for a supercab shortbed 4x4. if you all hear of one reasonably close to louisville ky. let me know
shoobear
Apr 11, 2010 07:32 PM
twwtruck
1983 - 2012 Ranger & B-Series
Mar 23, 2008 07:46 PM
ar29456
Engine Swaps
Jan 25, 2007 04:48 PM
mfriesen
Dec 7, 2005 07:13 PM
wild_louie
Aug 5, 2004 10:28 PM
