Steering
Old Apr 6, 2012 | 06:44 AM
midsouth's Avatar
midsouth
Steering
On my 1983 f-150 4X4 5.8 liter truck, the truck is hard to keep on the road. The front end has been checked out, and aligned, and am told nothing is wrong. I have to constantly fight the steering to keep the truck straight. Is this normal? Would it be a sign of the steering box wearing out?
Old Apr 6, 2012 | 07:45 AM
82f100460's Avatar
82f100460
I have somewhat of the same issue, I think, if I understand your correctly.
I have replaced all of the steering linkage and joints but I have some slop in the steering box, which happens as they age and wear.
The symptom is that you have some slack in the steering wheel. Feels like you have to turn the wheel a bit before it starts to respond. Then when you go back the other way you have to take up that slop again. So you end up with some free play where you are moving the wheel and nothing happend until that slop is taken up.
If that's what you are feeling then yes, it is probably a worn steering box. Assuming the rest of your steering and suspension is in good shape as you state.
Old Apr 6, 2012 | 07:48 AM
82f100460's Avatar
82f100460
Also, if you have added much larger tires, this will make a loose steerting worse. The more rubber you have on the road, the more it's going to try to wonder.
Old Apr 6, 2012 | 08:06 AM
midsouth's Avatar
midsouth
Is replacing the steering box better left to a qualified mechanic? Which I'm not.
Old Apr 6, 2012 | 08:12 AM
82f100460's Avatar
82f100460
Well....hard to say without knowing your experience level.
In my opinion it is not real complicated. There are some special tools you will need to get the pitman arm off and sometimes getting it loose from the steering column can be difficult.
It's not the most difficult thing to do on these trucks. If you're mechanically inclined at all, I would go for it. Get a manual and follow it. Most parts stores like advanced or O'Reilly will have the tools to loan you or rent to you.
Kinda comes down to how urgent it is. If it's a daily driver and you gotta have it now....then that may weight toward having some one do it. If you don't need it right away then my vote would be go for it. You have all of us if you have questions along the way
Old Apr 6, 2012 | 01:38 PM
Ken Blythen's Avatar
Ken Blythen
There is an adjuster to eliminate freeplay on top of the steering box - a screw with a locknut.
When I bought my truck the rod ends, kingpins & bushes, wheel bearings etc were all tight but the truck still wandered dangerously.
Replacing the rag joint helped slightly, but tightening the steering box at the adjuster took out 90% of the play.
The Haynes manual gives the adjustment procedure.
But if the steering box is too worn, you won't be able to adjust all the slack out, without creating other symptoms like binding. A rebuild is necessary at that point.
Old Apr 6, 2012 | 03:18 PM
ctubutis's Avatar
ctubutis
Or losing the wheel's tendency to want to return to center by itself after a turn.
Or losing road feel.
This is one of those things can easily be messed up if misadjusted, be careful here and be sure you can return the settings to how they were.
Old Apr 6, 2012 | 06:30 PM
bruno2's Avatar
bruno2
Pay attention to clocking positions when replacing the sector box. You can lose travel in one direction or the other if everything isnt centered up just right when it goes back together. The wheels have to be centered and the position of the sector shafts have to be centered.
Old Apr 6, 2012 | 07:01 PM
82f100460's Avatar
82f100460
yep....neighbor did that on his old Torino. Ended up with about 2 turns in one direction and 6 in the other. That's fine if you circle track racing but a bummer on the steet....even worse in a parking lot
Rachel Moody
15
Jan 16, 2017 11:51 AM
Fordsdad
Nov 21, 2013 06:52 AM
SIRed
Mar 2, 2010 03:23 PM
13MWZ
Nov 24, 2007 05:38 PM
