Key cylinder
Old Apr 4, 2012 | 02:31 AM
WD4B's Avatar
WD4B
Key cylinder
How hard is it to replace the ingnition key cylinder in one of these trucks? I don't know how public I should be making this, but what tha heck . I don't have to have a key in the slot in order to turn/start my truck. Just wondering if its worth fixing.
Old Apr 4, 2012 | 04:22 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Simple and the part is cheap.
I never bothered until I moved to a bad neighborhood.
Old Apr 4, 2012 | 06:22 AM
1986F150six's Avatar
1986F150six
WD4B,
Any parts store will have the replacement cylinder. It will be less than $20 and the instructions will walk you through the procedure.
Old Apr 4, 2012 | 06:59 AM
critterf1's Avatar
critterf1
Usually a 5 minute change/repair.
Old Apr 4, 2012 | 09:14 AM
Blue86's Avatar
Blue86
Twist the key to 'ON' slide a tiny allen or other thick paper-clip-esque object into the access hole under the lock cylinder on the column and pull it out. Set the new one to 'ON'. Push it in. Turn it to off. Done.
Old Apr 4, 2012 | 08:12 PM
WD4B's Avatar
WD4B
Awesome guys. I would have never thought it was going to be that easy.
Old Apr 5, 2012 | 10:04 AM
1983F1503004x4's Avatar
1983F1503004x4
I don't know if it's different if you have a tilt column...
But to do it, you also have to pull the steering wheel.
Pull the steering wheel, stick the old key in or just turn it to RUN if the truck's cylinder turns without a key (like mine did).
Like they said, a small allen key or a paper clip to push in the retaining pin, slide it out, slide the new one right in.
ALSO, the steering wheel will have an index mark on the splined shaft and the plate that sits under the steering wheel nut. Use those so you don't have to worry about lining them up.
Old Apr 5, 2012 | 10:47 AM
ctubutis's Avatar
ctubutis
Insert sound effects from 'Home Improvement' TV sitcom - Huhhhhhhhhhhhhh??????? ;)
Hmmm... Are you sure, did something change? The 1981 factory shop manual says differently, but maybe it changed in later years?
Anyhow, from the 1981 shop manual:
Old Apr 5, 2012 | 03:55 PM
bruno2's Avatar
bruno2
Even the newer ones are the same. My 87 Bronco and 96 F 250 all have the pin you push in with a punch or precision screwdriver. Then pull the old one and reverse procsdure for the install. Shouldnt take 5 Minutes.
Old Apr 5, 2012 | 06:10 PM
82f100460's Avatar
82f100460
I've never had to pull the steering wheel...but certainy haven't done it on all different generation / configurations either
Old Apr 6, 2012 | 02:41 AM
Blue86's Avatar
Blue86
Mine is tilt and you don't have to pull the wheel.
Old Apr 6, 2012 | 10:00 AM
1983F1503004x4
Chris,
That's what I was thinking, that it was different for tilt-steering models.
Mine is non-tilt, and to remove the lock cylinder, you use the procedure in the photo you provided above.
You don't HAVE to disconnect the battery, but if you aren't careful it'll cause some sparks and maybe the horn to go off. Ask me how I know.
The tilt-steering models look like the pin is just below the key cylinder, on the outside instead of the inside like the non-tilts.
Old Apr 6, 2012 | 10:02 AM
1983F1503004x4
Just was looking back through the thread and you said you didn't have a key.
You should be able to take a drill and drill out the tumblers in the lock cylinder by going in from the key hole. Go a little at a time and test until you can turn it. Don't go too far or the little gear thing on the end could break off or you could put metal shavings all in the steering column.
Old Apr 6, 2012 | 10:14 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I think he's saying he doesn't need his key to turn the cylinder.
I know my old one was like that.
Old Apr 6, 2012 | 10:58 AM
ctubutis's Avatar
ctubutis
There is actually a Ford-official, documented procedure for this very thing.
https://www.ford-trucks.com/forums/1...l#post10346100
