- Whistling from the engine compartment
- MAP Sensor Testing - 1989 Ford Van - 5.0
- HELP!! Check Engine Light On...
- 5.8L embarassingly died, with no restart
- Spark Knock?
- Mileage topic - opinions wanted
- years need from month to month
- looking for a 87 or 88 4.9 pickup owners help
- '87 Still not Starting
- low compression....
- Dump bed kit
- fuel gauge problems
- Speedo problem...
- Rarity of the 460 Engine
- For all those with 87-early 88 F-150/Bronco with the flange hubs
- Help! Removing rear driveshaft, 88F350
- I6 300 starter grinding not turning motor
- 89 f-150 stalls
- Recalibrate Speedometer with Gear Change?
- Heat coming out of vent
- wiring issue
- E4OD transmission slipping
- Slam It or Jam It?
- noises driving me nuts
- low idle
- auto hubs
- Speed Sensor Recalibration???
- Door lock actuator
- Steering wheel swap
- engine swap
