- pipes/hoses rear of block
- Where is the oil pressure sensor on a 460?
- turbo
- Leveling kit? Front end too low...
- details on I6 going into a '87 V8 auto
- headlights kill the engine
- Hit a deer last night
- Show your stang or other ride!!!!
- 87 F150 Roar
- Nothing's WORKING...
- code 181 questions
- bigger tires in the back?
- Stuck screw
- High idle at startup then drops to normal?
- Diesel wiring vs. 351w wiring???
- Fuel Lines 93 bronco
- Headlight switch problem
- Is the mileage really this bad?
- Transmission, U-Joint, Rear end or ?
- Long Tubes...emission friendly?
- 97 F-250 AC Blower Speed changing on its own!
- Old Trucks
- Can I disable the smog pump
- How Bout Some Lifted/Mudding Pics!
- trans swap
- 351w 351m engine swap
- Not the Vss vehicle speed sensor -- now what?
- I HATE my summit headers!!!!!!!!!!!!!!!!!!!!
- Making Some Radius Arms
- No spark 5.0 89 F250
