- 1990 Ford F350 351W block
- Engine compression????
- EGR valve????????
- GT-40 head swap on 1993 5.0
- Engine Treatments?
- It's Broken and I can't get out!!
- Mazda tranny woes
- Tach won't go below 2500
- M5OD- sloppy shifter woes
- URGENT- battery cable?
- high idle (1000-1100 RPM) on 89' 302
- New 31" tires!!
- Fuel pump
- Can't stop the '96 Windstar!
- front wheel bearings
- Air Boxes
- BAD BAD SHUDDER IN FRONT END!
- 351w motors
- t case questions
- carb
- pcv reroute warning
- 1995 F-150 Questions???
- Plastic Radiator Leaks
- looking for rebulit
- LCD Odometer
- Intake manifold flow numbers
- EGR and Canister
- new exhaust question
- removing cats, air pump,etc....
- Radiator Hose
