- ocassional popping in exhaust during part throttle
- upgrade headlights from 88 to 92?
- Can`t find horn relay ..
- Mileage Increase - 5.0 F150 4x2 3.08 Ratio
- Throttle body 4.9 5.0 5.8
- Different size rear wheels what does this do..
- gas tank
- 1991 F-250
- Fuel smell inside cab
- 327 - EVP or DPFE circuit below minimum voltage
- Door Courtesy Lights
- '89-F150 FUEL PUMP RELAY RUN ON
- Fuel filter change???
- coolant flow
- Check Engine Light
- AMP install in a 92 XLT
- Loose steering wheel
- Heat won't turn off
- Keys
- The truck is running funny
- Help! Won't start!
- What year did the 5.0 roller start in trucks
- 92 cruise control
- 88 f150 vibration
- '94 F150 XLT keyless entry???
- gears & chips
- '94 wiper switch??
- Hard 1-2 shift '94 F150 302 2wd
- Compression test
- 94, F150 XLT, 4x2, 4.9L, 5 spd Alternator Problems
