HELP!! Check Engine Light On...
Old Aug 5, 2006 | 07:19 PM
btwick's Avatar
btwick
Hi,
Have a 96 F350 with a 460 gas motor.. Today I changed the oil, oil filter, put some coolant in the reservoir, and serviced my K&N air filter.. Went to start it up and the check engine light went on... Double checked the electrical plug to the airbox (which is the only thing I can think of) and everything looks fine..
Any idea what I can check next? What can possibly be triggering the light with the minor stuff I did? I don't have a code reader so can't tell what it is..
Thanks in advance!!
Brian
Old Aug 5, 2006 | 11:27 PM
puck1263's Avatar
puck1263
go to the parts store and buy a code reader for $30, or fordfuelinjection.com
Old Aug 6, 2006 | 06:58 AM
subford's Avatar
subford
Well go to parts store and see if they can pull you codes. I do not think fordfuelinjection.com is going to help much with a 96 or you will be able to buy a reader for under a $100.00.
If you can get them to pull your codes post them back and we will try to help you.
Old Aug 6, 2006 | 08:13 AM
jroehl's Avatar
jroehl
Before you spend $50 driving to the auto parts store, check all your vacuum lines. They get brittle and break easily, or you could have inadvertently bumped one loose in everything else you did. With a '96, you may still need the parts store to clear the code for you, though.
Jason
Old Aug 6, 2006 | 02:17 PM
btwick's Avatar
btwick
Smile
Thanks for the tips everyone.. Turns out I used the truck this AM and after about 25 miles the light went off.. Turns out these Fords are self-healing, and I got my Sunday back for other errands ;-)
Old Aug 6, 2006 | 02:20 PM
Nightrain's Avatar
Nightrain
The check engine light on my F-150 comes on periodically, but it soon goes off.
I'm starting to believe that it's the oxygen sensor, but I could be wrong.
I'm kinda like you, though... I believe they are self-healing!
Good luck!
Nightrain
Old Aug 7, 2006 | 07:43 AM
EPNCSU2006's Avatar
EPNCSU2006
A 96 F350 is still OBD-I meaning you can pull the codes yourself. You should be able to find out what triggered the light even though it cleared itself. It's probably nothing to worry about, but it would give you an idea of what the computer didn't like.
Old Aug 7, 2006 | 10:45 AM
subford's Avatar
subford
Red face
Your right, 5.8L Over 8500 GVW & 7.5L Over 14,000 GVW, 49 States & 7.5L Super Duty 50 States are OBD-I with the DLC and a 60 pin PCM.
Please disregard my post above and EPNCSU2006 thanks for pointing this out.
Go do what puck1263 said above.
Old Aug 8, 2006 | 01:22 PM
btwick's Avatar
btwick
Hi,
Thanks for the tips.. Called the parts store and they're telling me that the 96 and newer is OBD-2 at $95 to $200 for a reader.. The OBD-1 readers (according them is to 95) is only $30.
Anyway to be sure that my 1996 F350 uses an OBD-1 reader? Really hope it does..
Thx,
Brian
Old Aug 8, 2006 | 01:59 PM
Jean93's Avatar
Jean93
have heard that something called the mass air flow sensor gets confused if you over oil your k&n
Jean
Old Aug 8, 2006 | 02:11 PM
subford's Avatar
subford
Originally Posted by btwick
Hi,
Thx,
Brian
Sure, just look at the driver’s side back corner by the hood hinge. If you have a Test Connector there and none under the dash then it is OBD-1. Also if it fits the test that posted above your last post it is OBD-1.
A test connector:
http://i54.photobucket.com/albums/g9...taLinkConn.jpg
Old Aug 8, 2006 | 02:20 PM
andym's Avatar
andym
Your F-350 should definitely be ODB-I. A lot of the time parts store people don't know what they're talking about.
Old Aug 8, 2006 | 08:05 PM
btwick's Avatar
btwick
Funny, I see nothing back at the driver's side hinge, but I do see a data port sticking out under my dash.. Could be OBD-1 maybe? I am a 7.5L but not sure of GVW.. California car.
Thx,
Brian
Old Aug 8, 2006 | 09:05 PM
subford's Avatar
subford
Thx,
Brian
Sounds like you have an OBD-II, if the plug under the dash looks like this you do.
http://i54.photobucket.com/albums/g9...dii_female.jpg
Old Aug 10, 2006 | 10:09 AM
btwick's Avatar
btwick
Thanks Subford, I'll check tonight..
ranger9010
Oct 1, 2013 03:52 PM
MC5C
Sep 4, 2012 12:51 PM
junkford?
3.8 & 4.2L V6
Dec 24, 2007 07:33 PM
Terrafermi_1
Modular V8 (4.6L, 5.4L)
Mar 7, 2004 12:41 AM
6T8STANG
1997 - 2003 F150
Mar 23, 2003 07:18 AM
