- Its not cool
- Ammeter and Gas gauges not working
- Vacuum lines only at Dealer?
- Breather tube/K&N air charger kit question
- Advice on the loose tilt steering wheels.
- Brake problem
- 88 f-150, 5.8L fuel pump runs with key off
- stock clutch fan CFM's
- Truck wont start?
- Leaking Fuel Tank
- F-150 Camper Possibility
- Eliminate front tank
- 1991 f-150 clutch
- monster electric fan
- change
- wiper issues
- rear end seal
- Gas tank differences 87-89 & 90-96
- Does anyone know?
- No output from coil '89 ford f150 5.0 fuel injected
- Truck still running rough, stalling on cold startup, losing power, etc.
- What is this port?
- New owner... used truck. Got a few questions...
- keeping electrical from getting wet...???
- knock sensor
- how to replace the stator/pickup coil in distributor
- self test code result
- Windshield Wiper Control
- High engine temp= Transmission slippage
- Questions about MSD, ignition timing and running rich
