- I think my rad is cracked, replacements?
- Temp. Sending Unit 1990 F150
- Transmission Problem, or not?
- truck will not start
- CSI: Code Scan Interpretation, Solve the mystery
- Water and Oil sending units
- gas problems
- Throttle Body and Mass Air Sensor Question
- 95 F250 Rad Support Cracks
- Windshield Washer Doesn't Work
- Folks, did ANY F150 from this era (87-96) come as a stock crew cab?
- Is Fuel Pressure Regulator A 'Wear-Item'?
- Where can I find a dash mounted heat/cool control switch?
- Doorlock Problem
- 95 f150 4x4 problems
- Re-attaching door moulding
- F-250 deisel tow capacity
- Vibrating f150 powertrain/clutch problems??
- 1986-1996 Ford Truck FAQ We Need One!! Important, Please Read
- Code Diagnosis
- Gaps for spark plugs??
- Starter/flywheel problem
- color/pinouts of 89 F250 dash cluster wire harness
- Too Cold?
- Aftermarket Oil preasure gauge
- Yellow spark plugs
- big hesitation
- 88 F150 Overheated, not sure why
- Melted Connector
- clockspring? loss of power?
