- Idle Air Valve, low idle speed
- 91 F150xlt
- Harmonic balancer came apart?
- Bug or feature?
- bad tranny leak
- IAT/ACT sensor location on 7.5L
- Fuel Pump problem!!
- Rims
- F150 vs F250 manual trans
- Computer
- Bed rail caps
- 5.8, gt40 heads and compression, general update
- Clutch, slave cylinder and throw out bearing replacement issues
- need more power f150
- 88 Door Hinges Vs. 85
- 95 5.0 transplant to 93 5.0
- 1990 F250
- Im gonna try one more time...
- valve of some sort not closing?
- shifter problems
- 93 ford 150 no oil pressure
- Monro Sensatrac
- 3/4 ton suspension under a 1/2 ton?
- All of the sudden mushy brakes
- Timing!
- 96 f150 cruise horn and air bag not working
- Won't start
- 1995 F-150 problems (erratic failure to start)
- 94 F150 5.0 engine temp hot
- Onboard inflation THROUGH axle
