- A/C switches to defrost on its own!
- Power steering filter
- Volts go down when in idle
- Set me straight will ya?
- high idle up and down
- 5spd to AOD
- Higher mileage OK?
- Funny stuff on a 95 ford
- custom interior
- vacum diagram?
- 1996 F-150 - 302 has a mis
- From 8.8 to 10.25
- help on front end
- Questions, Questions, and even more Questions!!!
- intermittant cold no start
- belt buckle
- 4wd indicator light
- "abs" light on update
- is main bearing going bad
- converting from EFI to carburator
- '90 F150 4wd autolock removel???
- Hot engine high idle
- No Start - Code 95
- Spark plug gap cause pining?
- Fan Clutch?
- 92 f150 on a 79 frame ??
- 1 Question about motor swap.
- Extended driveshafts on 6" Lift
- possible heater core?
- Motor Conversion
