- door jam sticker
- EGR valve question
- Lmc?!
- replace pickup coil, how?
- Did a tune-up and still puffing
- Tune up
- Few common questions?
- Correct oil sender for 1988 F250, 302 V8?
- OBD II code help
- testing coil for spark
- Crusie Control Issues ???
- New truck! (2 me anyways)
- FIX!! Intermittent cutting out and turning a corner too
- I think my ALT is going out!
- Cleaning out Evaporator Drain / Water Sloshing
- swaped a 300 i6 for 302 v8 run great before it went in know it seems to run on 2cly ?
- Weak Engine
- Instrument cluster issue
- 95 F-150 check engine light
- making a 2 wheel drive in a 4x4
- motor difference `
- Bushings 101
- K&N Gen.1 or 2?
- Just saying a long hello
- gas tank question
- Anyone use a grannatelli MAF sensor?
- 92 f150 5.0 fuel filter removal
- Hiccups, sputters under load 93 5.0 EFI
- inertia fuel switch
- 1988 F150 CEL problems
