- Looking at a 1989 XLT with 176K
- Detergent motor oil???
- Pulling codes for free ?
- Timing problems
- pulled code 300, 303 & 307, still rough
- '94 302 for an '88 model
- Slow idle at start up
- Need Help! Clutch Lever alignment Issue...
- who votes U-joints
- air bag light temporarily turned on
- How to remove brake hose clips?
- Replacing Fuel check valves
- temp gauge
- Looking at a Truck...
- Anyone know the knock sensor wire colors 92 F-150 302
- Power steering problem
- F-series trucks in movies
- Check engine light-codes
- turn signal cam
- bench seat in bed?
- Bleeding Brakes
- Starter engaging by itself
- '88 F-150 loose gear shift
- tranny hunter
- Does Ford still use the 9" rear???
- Subwoofer for standard cab?
- shaking f-150 front end
- how do i replace my fuel check valve
- good deal on 94'??
- door handles...
