- Replaced main/rod bearings now Zero Oil Pressure??
- 1990 F-150
- cheap and easy mods for 302?
- elec. fan switch
- Starts then stalls, but only when left out in the heat
- K&N on a 4.9 I-6 ?
- universal joint replacement
- my thirst for knowledge
- 89 302 150
- 4x4 parts interchange?
- 1990 F150 I6
- do digital odometers go over 100k mi?
- Fuel Pump Dying?
- 91 F 150 Ignition switch
- 1991 F150 Ignition Switch
- Drivers Door Hard to Close Unless Window Down (???)
- '88 F150 Starts and stalls in hot weather
- 2600 rpm's up to 3000 has no power
- odometer in 1994 f150 XL
- stumped on evp
- Failed Emission Test - Problem with EGR system
- Odd intermittent vibration, what could be the problem?
- captain's chairs armrest
- stock hood/front fenders/bedsides VS fiberglass in WEIGHT
- fuel selector switch? air leak? water?.. stumble, fuel starvation I think
- Ball joints - how to tell when bad? Are they bad?
- "Creaking" sound in 91 F150
- Need to learn how to pull diag. codes 90 F150
- Camper for my `95 F150...
- 6 MPG Tune up Questions
