Sponsored by: Real Truck
Gas vs PSD
Old Jan 1, 2011 | 04:53 PM
  #10291
2001400ex's Avatar
2001400ex
Originally Posted by Old93junk
Not trying to slam you 2001400ex.........But if you come through Oregon towing that kind of load at 70-75 mph, I don't care if you have diesel or a V-10........Step it down a notch on the speedometer......my wife and kids are out the same roads......I do not want to see you on the OSP website with your toys scattered all over the highway.......That kinda speed, that kinda load, our lousy roads.......not a good combination.....just a friendly suggestion.
Everything except the last 50 miles down to the coast is on I-5, with a 70 mph speed limit... So please get off your high horse, of course on 101 and the roads down to the coast we did not go that fast, and I got about 15 on that section.... (with in town driving, all loaded). So don't bring your kids into it, seriously.
Originally Posted by X_Hemi_Guy
This picture tells me you have no concept of WIND RESISTANCE...this particular load is almost like being unloaded.
Also you have to factor in COST OF FUEL...which you haven't once mentioned...you should go farther on a gallon of diesel...it costs you more!
The part you are missing is that BOTH motors are extremely capable and I have proven it with my criss-crossing the USA tugging my 9000# brick climbing some massively long, steep and high altitude grades with not much of a hiccup with my V10...the V10 is a work horse and the 2007 Shootout showed by an independent source that even when the V10 is clearly out matched with HP and TRQ...the V10 STILL pulled it at a higher MPH at the end of the pull...it is no surprise to me that the initial umph of the PSD gets the load moving quicker...but the underpowered V10 clearly has better top end.
I tow 12-14 hour days when I am towing and I am the only one driving...the V10 for me has proven to be completely reliable and relaxing to drive.
If you read the shootout from 2007...the Duracrap actually is a BETTER diesel motor than the 6.4L...what motor do you have in that girlie man bow-tie you are pulling that flat bed trailer with?
You can continue to bury your head in the sand...urr...hands...that is pretty obvious on how you roll.
Joe.
Reread what I wrote, my toy hauler is a brick wall as I call it. Yes I totally get wind resistance, and that is why I get only 8 or 9 at 70 mph with the toy hauler, your v10 would be closer to 6.
I get 2 to 3 less mph at speed with that load than empty, so no it is not like towing unloaded. If you get within 3 mpg towing that load with your v10 I would be surprised.
I am not concerned with cost, my concern is going further between stops. Since I live in Spokane, and it sounds like you just came through here, you should get my point. If cost were my concern, I would have bought a 2002 7.3 or Duramax. Not a huge premium over the gas engine, and better mpgs. I frequently travel I-90 from here east through Montana to Billings, or to Butte and down I-15 into Idaho. There are very few gas stations on that route. My Chevy 6.0 gas engine would only get 140 miles per tank, I would imagine the v10 wouldn't be much more with my toy hauler loaded, especially in the wind you can get on that trip.
Yeah, that is an 08 GMC with the the Duramax. I get roughly the same mpg as my 6.0, a little less since it is bone stock. I got it because it was my time for a newer truck and the 6.4 Ford gets less mpg than the Duramax. Also, my wife drives my truck in the winter when I am gone a few times. She does not like how the Ford drives. Gotta keep the woman happy too.
Also, reread my comments. I have never said it is not capable, just not for me. I don't like revving to the moon and I don't like only going 180 miles on a tank of fuel. Yes I could spend 1,200 on a Titan tank, but that is not an upgrade I prefer to do.
Originally Posted by David N.
You might want to re-read the article yourself. There was no V10 in the 2010 shootout.
Yes, techically it is the 6.2, but the principle of my comment doesn't change. The PSD is presented in dually and srw forms, and the dually is a little slower, even with higher gears. Doesn't matter what the gas engine is. Reread my comment... LOL
Man you guys are brutal today.
Old Jan 1, 2011 | 05:00 PM
  #10292
2006lariat's Avatar
2006lariat
Joe.
WOW A V10 vrs. PSD, Vrs. Duramax thread! Holy cow! Over a truck, really.....
Old Jan 1, 2011 | 05:01 PM
  #10293
2001400ex's Avatar
2001400ex
Of that 1170 lbs difference, about 765, or roughly 2/3, is because of the engine. The dual rear wheels adds only about 405 lbs of it.
The graph of speed shows that, with the exception of 0 to 100 meters where the diesels low end stands out, the two Fords were very similar. Acceleration from 100 to 200 meters was virtually identical, while the gas accelerated stronger from 200 to 300. Above that, they are again nearly identical. From the chart, it is clear that the top speeds of the two trucks would have been very close, which is to be expected with two engines with a difference in peak power of only 12 hp. Assuming both engines made the rated power, the gas would probably have a 1-2 mph higher top speed up that grade with that load. However, there is probably more than enough variability in the output of each engine from the factory that given 6.4 could be stronger than a given 6.8.
Don't forget to factor in wind resistance... the rear wheels create a less aerodynamic wind profile, which also affects performance.
Old Jan 1, 2011 | 05:04 PM
  #10294
SoCalSuperDuty03's Avatar
SoCalSuperDuty03
Hey Bare Bones, I hear you! 10,290 replies... That is crazy!
Old Jan 1, 2011 | 05:06 PM
  #10295
Old93junk's Avatar
Old93junk
OK.....I was trying to friendly about it, you took an attitude.......Speed limit on I-5 in Oregon is 55mph for vehicles towing trailers, except 60 in a few select areas. I guess you are just another out of stater blasting through, dragging your noisy toys over to the dunes.......I am done with this and you.....Have fun.
Old Jan 1, 2011 | 05:30 PM
  #10296
2001400ex's Avatar
2001400ex
This is the definition of a truck on Oregon:
"(A) A motor truck with a gross vehicle weight rating of more than 10,000 pounds or a truck tractor with a gross vehicle weight rating of more than 8,000 pounds."
My GVW is like 9,200 pounds, so I am not considered a "truck" in Oregon with that load. So yes, technically it is 65 for the speed limit, so we were doing 70 for that portion of the trip (and only 65 in Eugene and 55 or whatever in Portland).
I just don't like people on forums trying to make other people look like they are committing a crime or something or endangering their family, of which I did neither. And other than going 5 mph over, yes we obeyed all laws in Oregon, and you don't know me or what I contribute to the state of Oregon and the local communities I visit.
Go back to your bunker and reload, I am going back in a few months, you might need to shoot at me to save your family.
Old Jan 1, 2011 | 06:53 PM
  #10297
David N.'s Avatar
David N.
From your earlier comment:
If you don't think that makes a difference, go to the 2010 shootout. And the v10 still got beat by 5 seconds.... in only 700 feet.
Sounded to me like you were saying the V10 got beat by 5 seconds in the 2010 shootout.
Old Jan 1, 2011 | 07:06 PM
  #10298
2001400ex's Avatar
2001400ex
Yeah, two separate thoughts, in the same paragraph. LOL I do that sometimes. The V10 got beat by 5 seconds on the 15% pull, in 700 feet in the 2007 shootout.
Old Jan 1, 2011 | 07:09 PM
  #10299
David N.'s Avatar
David N.
Definitely, and it would probably be very significant at higher speeds unloaded. But on a steep grade at or near GCWR, the majority of the load is due to the weight itself. Depending on the size and profile of the trailer, the DRW may not hurt that much. Without knowing the drag coefficient of both trucks (SRW and DRW) with trailer, it's impossible to say, but fully loaded on a 5-7% grade, I doubt that DRW would lower top speed more than a couple MPH--even less on steeper grades.
Old Jan 1, 2011 | 07:38 PM
  #10300
2001400ex's Avatar
2001400ex
2010 HD 7 Percent Hill Climb Test - PickupTrucks.com Special Reports
Here is my point, Look at the 7.2% grade, the dually with 3.73s was almost a full second slower than the srw with 3.55s and more than 3 mph slower. Put 3.73s on the srw and see what the difference is. And yes there is 2,000 pounds more on the dually.
So that example isn't the best, but look at this:
2010 HD Quarter-Mile Acceleration Test (Unloaded) - PickupTrucks.com Special Reports
Dually is about 2 mph slower on the 1/4 mile run, even with 3.73s vs. 3.55s on the srw.
so yes the weight and aerodynamics do mean something.
Old Jan 1, 2011 | 08:26 PM
  #10301
X_Hemi_Guy's Avatar
X_Hemi_Guy
I track EVERY mile and gallon of fuel I drive/pump and hand calculate the mpg's.
My running AVERAGE for TOWING miles is right at 8mpg.
some tanks are less and some tanks are more but the AVERAGE for all those towing miles is right at 8mpg.
I drive between 62 and 65 on the interstate. My TT is a tall TT because of the slides so I fight wind constantly even on calm days.
I will drive 70mph when needed for SHORT DISTANCES. If you check the speed rating on your ST tires on your trailer you may be surprised what you find...
I drive an Excursion...the Ex has a 44 gallon fuel tank so I typically go 280 miles before stopping and I usually have 10 gallons left as a "cushion" in the tank. Plus I have 3 women in the truck and I can't hardly go more than 2 to 2.5 hours between "potty" stops...stopping at 280 or so miles on the odom means every other stop I stop for fuel and potty...of course there aren't many vehicles out there with a 44 gallon fuel tank...
Joe.
Old Jan 1, 2011 | 08:41 PM
  #10302
plgebbia's Avatar
plgebbia
Originally Posted by bill11012
South west of Austin it gets pretty hilly, and I know 2222 in Austin has a 6% 1/2 mile grade. Problem is that one has a 45 MPH speed limit and traffic won't let us go any faster. Give me warning before you come down and I can find something that will work.
You coming empty or bringing a trailer?
Won't you still have more power than stock, even with a stock tune?
No, because I will still have stock nozzles on the injectors, so stock tune should be stock. But I do know that my truck right now with just a straight pipe and intake, will eat a stock 7.3L, especially low in the rpm band.
Oh, and last "hill" I pulled was 6% for 5 miles.....
Chances are I would be pulling a trailer, but don't know for sure.
Old Jan 1, 2011 | 08:59 PM
  #10303
plgebbia's Avatar
plgebbia
Joe.
Isn't the above statement a scientific contradiction???
If (x) motor has more HP AND more TQ it will outpull you period. Untill you throw gearing and tranny into the mix...... The only reason your V10 can hang with my 7.3 or 6.0 or 6.4 is because it can drop another gear or two, turn 50-85% more rpms, thus multiplying the torque created by the motor. It isn't the motor so much at that point, its the drivetrain helping you out.
A diesel will outpull any gasser in a 1 to 1 gear ratio every time.
My 7.3L just makes way more torque per RPM.
Old Jan 1, 2011 | 10:00 PM
  #10304
tgreening's Avatar
tgreening
Jesus H toe tappin Christ. FINALLY, someone else realizes how stupid the whole V10 vs argument is. People in here pretend they're arguing motors when in reality they are arguing drive train PACKAGES. Completely different ball game.
Old Jan 1, 2011 | 10:23 PM
  #10305
SoCalSuperDuty03
When I haven't been at FTE for a while, I don't realize how much I miss it! This place is soooo entertaining!
Hey plgebbia, I used to have a really nice white '96 CC 7.3 truck like yours, except mine was a 4R100 truck. My little girl (she is a 12 year old gearhead!) still calls it 'The Early Superduty'. I would have kept that thing forever, but I got talked out of it by one of my friends. I still love those '92 and later trucks, and if I ever find another as clean as mine was I am going to buy it.
