Sponsored by: Real Truck
Gas vs PSD
Old May 28, 2011 | 08:33 PM
  #11791
william_04_x's Avatar
william_04_x
Originally Posted by Kajtek1
More like it can't. The super heavy engine components will not handle the centrifugal forces.
Which components are heavier? The cranks can be heavier, but they are stout and can be spun faster than 5k.
The long stroke of a diesel creates higher max piston speeds, and that's what dictates the ratings of the internals. The rods are what can't take the linear loads, as the crank tries to rip them in half pulling the AL pistons back from TDC.
Old May 28, 2011 | 09:17 PM
  #11792
David N.'s Avatar
David N.
Originally Posted by parkland
They should either start a new testing procedure, or i dunno, but its BS.
They did revise the testing procedure a couple years ago--mostly to rate hybrids a little more accurately (read lower)--and rerated older cars (also mostly lower), too. But for some cars, like my Thunderbird, I think they got farther away. (I'm actually surprised Johnny's mileage is as low as it is.) When I was doing mostly highway driving, usually 70-80, sometimes more, I consistently saw at least 24-25 mpg average. It was rated at 24 highway, and I was disappointed anytime I saw less. Now I think its rated at 22.
Old May 28, 2011 | 09:22 PM
  #11793
Super08's Avatar
Super08
Now that we cannot get the venerable 6.8 V10 in the 250 ~ 350 I wonder if we should start a 6.2 vs PSD thread...
Old May 28, 2011 | 09:39 PM
  #11794
powerstroke72's Avatar
powerstroke72
Good thinking.
I started one here:https://www.ford-trucks.com/forums/1...l#post10397749
It's a 6.2L V8 versus pretty much anything thread.
Old May 28, 2011 | 10:07 PM
  #11795
Kajtek1's Avatar
Kajtek1
It is common engineering knowledge that when strength of the part increase with square of the size, the weight of it grows with cubed.
So the bridge build out of matches can hold multiply of its own weight, the same bridge build in full size will collapse under its own weight.
Coming to the engines, in my teens I was playing with miniature engines. Those normally operated at 16,000 rpm, while in different application friend run them at 24,000 rpm. The size of the cylinder was 2.5 cc, or bigger tablespoon.
Now seeing 1 liter cylinder spinning its 100 lb above 10,000 rpm would be something
Old May 28, 2011 | 10:15 PM
  #11796
bill11012's Avatar
bill11012
Modular motor junkie
It will run away from anything ( stock ) other than the new 6.7.
Old May 28, 2011 | 10:20 PM
  #11797
Super08's Avatar
Super08
Cool I was hoping it would have the sporty feel my old V10 had.
Old May 28, 2011 | 10:42 PM
  #11798
mwsmith100's Avatar
mwsmith100
For me it was a matter of economics
when I was shopping on craigslist in the SF bay area, I saw tons of V8s priced low (which I what I wanted since the truck is used mainly for occasional weekend hardware store trips and some towing), but the PSDs were a good $4000 more or so, or had such high mileage (fleet trucks) I was afraid the interiors would be thrashed.
Then this V10 came along that was maybe $1000 more than the average cheap V8 F250 and I jumped on it given it's condition in and out and the additional torque.
Old May 28, 2011 | 10:43 PM
  #11799
mwsmith100's Avatar
mwsmith100
Ford service manager agrees on that....
Originally Posted by exiled
If inwas a betting man I would too. I went into a walmart the other night and it was getting remolded. The company had 5 SD work trucks 1 250 the rest 350/450s. I noticed a 05ish 350 I walked and asked and he said it was an 05. It had 372k miles. Only has had 1 turbo put on. If the story is true thats nuts.
said he has seen plenty of PSDs with 350K miles and up on their first turbo.
Old May 28, 2011 | 10:45 PM
  #11800
mwsmith100's Avatar
mwsmith100
But he was talking about 7.3L only
even he admitted the later PSD turbos are much less reliable, and he has no reason to tell me that.
Old May 28, 2011 | 10:46 PM
  #11801
exiled's Avatar
exiled
Why don't you think it'll pull away from the 6.7? I can go ahead and tell ya I've already been beat by a v10. Kevin and I had to run em. I don't think it would have been as close as it was if he hadn't spinned on take off. He ran me down.
The 6.2l is somewhere between the 5.4 and 6.8l as far as power from the seat of pants. Its an awsome motor none the less. I enjoy driving it. I like how my 6.0 pulls better and kevin perfers his 6.8l. We're not say it can't pull. Its just not the same experence.
  #11802
mwsmith100's Avatar
mwsmith100
right then a 2010 PSD drove by the service entrance spewing smoke
and he admitted they had just installed a "$15K replacement engine", as he put it.
Old May 28, 2011 | 11:20 PM
  #11803
exiled's Avatar
exiled
What are you saying? I haven't said I seen lots of anything. I don't think the turbos are unreliable either. Why I think a 300+ truck is nuts in this great of condiction is because of the fact its a construction companies truck. It idels alots prolly gets oil/air filters changed when there's nothing else to do. It wasn't the fact it was a 6.0 its the fact any truck survive that use.
Old May 29, 2011 | 08:42 AM
  #11804
driximus's Avatar
driximus
If I was picking up a new truck I would be with the ECOBoost engine. the torque curve is sic, and its a direct injection motor. And Turbo
Old May 29, 2011 | 09:33 AM
  #11805
Johnny Langton's Avatar
Johnny Langton
This car never got any better than 20 mpg on the stock tune no matter what I did with it. It was very predicable in that manner over the 150K miles I ran to bone stock tune. Now, after tuning and alot of small adjustments and tweaks to the tune, I would get 24-26 on the highway only and would average 18 in most of my driving.
Now, with roughly 140 hp more power available, around town it gets 13-14 (mostly due to the 4000 stall converter and spending alot of time in 1st gear), and mixed driving will get 16-18. But highway trips are just over 20. I'm not gonna complain really-a high 11/low 12 second N/A car that weighs nearly 3700lbs with a little 281ci engine that gets over 20 mpg.
JL
