Sponsored by: Real Truck
Gas vs PSD
Old Jan 3, 2011 | 12:49 PM
  #10351
plgebbia's Avatar
plgebbia
Originally Posted by Krewat
Yes, they did. I only watched the 6.7, and the V10 video.
It seemed the 6.7 definitely got it moving off the line way faster, but didn't pickup a lot of speed after it shifted out of the lower gears. Not sure if that was a throttle-control thing by the driver, or it really was that way.
However, it is interesting to see how much of a difference there was between a second-generation V10 (2-valve PI head) with the lame 4R100 4-speed tranny and 3.73 gears, against a brand-new 6.7L PSD with the 6-speed.
It was also very interesting to listen to the tranny temps between the two. The 6-speed was actually hotter after the pull than the 4R100. But then, that might have something to do with Mike/5-star's tune in the V10 changing the shifting around a lot.
So there was a tune on the V-10? If so, where is the fair comparison?
I thought this was stock to stock.
Old Jan 3, 2011 | 01:22 PM
  #10352
David N.'s Avatar
David N.
Not all of the diesels were stock, the trucks weren't close to the same years, and there were a lot of other variations. They were pulling for fun.
Old Jan 3, 2011 | 02:01 PM
  #10353
krewat's Avatar
krewat
FTE Leadership Emeritus
On a 2-valve V10, there's not a huge difference between "stock" and "tuned" like there is with a diesel. However, there are shift changes made by Mike's 5-star tune that helps in the torque-converter lockup for instance.
If the V10 had a blower or a turbo on it, it might not be a "fair" comparison though
Old Jan 3, 2011 | 02:04 PM
  #10354
Monster-4's Avatar
Monster-4
Let's not forget that my truck is 5 to 11 model years older than the other trucks. What would you say if I compared mine to a 1989 truck?
Old Jan 3, 2011 | 02:10 PM
  #10355
CampSpringsJohn's Avatar
CampSpringsJohn
Well, based off the sounds coming through the videos, your truck sounded much cooler than any of the rest! I'm a diesel fan, but I really like the sound of a good running engine through a good performance exhaust!
If you were to compare your truck to a 460 powered 1989 truck with headers and turbo mufflers, both would sound great!!!
Old Jan 3, 2011 | 02:11 PM
  #10356
2001400ex's Avatar
2001400ex
Your truck performed pretty well actually! It was quite a bit slower out the gate, but still did well.
Honestly, though, I wish we could get all these trucks on a good 6% grade for 8 miles or whatever and see which one performs better. I know that type of test is harder, to most owners, it is more relevant.
Old Jan 3, 2011 | 02:15 PM
  #10357
senix's Avatar
senix
I know of an excellant 7% grade coming out of Western MD on I68. It is a few miles long. Best I can do up that one this summer was 55 at the top of the hill. That was with my 5er coming in at 15K for that trip.
I think it is about 3 miles long...or at least it felt that way.
Old Jan 3, 2011 | 02:17 PM
  #10358
Fishin76's Avatar
Fishin76
It's nice to see the comparison between truck, engine, and tranny choices. Although, too bad a 7.3L truck couldn't have made the trip. =(....
Old Jan 3, 2011 | 02:25 PM
  #10359
krewat's Avatar
krewat
Actually, to MOST owners, that test would be IRrelevant. That's basically a pull of 2500+ feet elevation all in one pull. Those conditions exist in about .1% of total driving by people using diesels in 3/4-ton and 1-ton trucks, not to mention gassers.
It would be FUN to compare them in a pull like that, however
Old Jan 3, 2011 | 03:01 PM
  #10360
Kajtek1's Avatar
Kajtek1
I don't know if I am in only .1%, but whenever I drive I have long grades.
Going South Grapevine Grade 7 miles at 6%, going East-North the Truckee Grade is like 24 miles with variable grades, but 6% seems to be pretty common.
Going East-South the grade past Bakersfield is like 11 miles and than have several more on I-15 where holding gas pedal on the floor for 1/2 hr is pretty common.
Going North -Shasta grade is well known as well.
Than I love the I-80 grade east of Salt Lake City where going down on neutral for 10 miles you have to brake hard to keep it below 80 mph.
Old Jan 3, 2011 | 03:05 PM
  #10361
2001400ex's Avatar
2001400ex
Yeah, but all these trucks can pull any load over flat ground just the same. Going up a 11% grade from a standstill is less likely than pulling a big hill. If all I did was drive on flat ground, I would still own my Chevy 6.0 gas engine... So yes pulling hills is than 5% of driving, but when you have to pull 4 similar hills in a 9 hour period, you might change your mind.
Old Jan 3, 2011 | 03:30 PM
  #10362
Monster-4's Avatar
Monster-4
Thanks! Tom, whom was driving my truck in the video, actually keep the window down so he could listen to the V10 belt out it's song the whole way up the hill. My exhaust mods are pretty mild. I have Ford Racing headers, and a cat-back Flowmaster system with an FM70 muffler. Everything else is stock and original as far I know/can tell.
Thanks! The real kicker is if I had the proper gearing the launch would have been much better. Not only am I running 3.73's but I'm running 33" tires (stock is 31") so I'm probably in the 3.5 to 3.6 range for gearing (to lazy to do the actual math).What really strikes me about these videos is that my old V10 that is 11 years a two gears behind the 6.7s was only 6-8MPH slower at the top. Yeah she wheezed out of the gate but once the RPMs were able to come up it took off.
I have no doubt as the altitude got higher I would be way down on power. I really wouldn't be afraid to let it rip and sing all the way up the mountain however. Might be annoying (depends on your viewpoint) and might not be the fastest way up and over but I think the trusty old V10 would do it, repeatably. Once again gearing would play a big role. If I was out west and climb the mountains out there a lot I would either have a PSD or invest in gearing to make up for some of the lost power at higher altitudes.
Really though I can't say enough good things about the 6.0, 6.4 and the 6.7. I love the diesel power delivery and if my needs were different and my pocket book was bigger I won't hesitate to own any of them. I'm not a gas or diesel guy but I am a Super Duty guy.
Old Jan 3, 2011 | 04:36 PM
  #10363
David N.'s Avatar
David N.
Plus all the other trucks had a lower first gear than you. 2.71 vs 3.09 or 3.97?
By the way, has your speedometer been adjusted to account for the larger tires?
Old Jan 3, 2011 | 04:41 PM
  #10364
CampSpringsJohn
If it hasn't, then his speed would have been better than what the speedometer was showing.
Old Jan 3, 2011 | 04:42 PM
  #10365
powerstroke72's Avatar
powerstroke72
I-77 from the NC line north into VA is a pretty good grade. There are varied opinions of the percent but they go from 4.5%-7% and it's about a 7 mile grade. It would make for a good run pulling that weight. You can get on at Exit 1 near the Love's Truckstop and go all the way to exit 8 at the top of the grade. Just sayin'....
Anybody wants to come down here and pull it, we could set something up. The grade starts from the time you hit I-77 right off the entrance ramp and continues all the way to about a 1/2 mile south of exit 8.
