Sponsored by: Real Truck
Gas vs PSD
Old Jan 5, 2011 | 11:43 AM
  #10411
Kajtek1's Avatar
Kajtek1
Originally Posted by bill11012
Originally Posted by Kajtek1
I always get chuckles when I read about towing on this forum. Per my observation it is me and couple other members who own F450-550 design for serious hauling.
Anyone want a challenge with me on towing 18,000 lb trailer, while having 9000 on the bed?
I didn't think so
A V10 F550 would have no problem with that load.
I already posted before, that while driving my sedan I quite often follow the V10 guys at 80+ mph (we do have 70 limit in CA)
Problem with them is that not much longer than 1 hr they have to pull over to gas station and I loose the radar shield
Old Jan 5, 2011 | 11:51 AM
  #10412
X_Hemi_Guy's Avatar
X_Hemi_Guy
Originally Posted by Fishin76
Also, the gasser must be able to use a wider rpm range to do the job near as fast as the diesel. It was proven in Crazy001's first set of videos that when the V10 is limited to (by way of the TC lockup) ~3000 RPMs, the truck ran out of steam going up the hill. But with 5-Star Mike's tune to delay the converter lockup, the V10 performed better due to using another 1000 rpm's or so.
In my experiences towing all over the country with the V10 BEFORE I had my tunes from Mike...the power of the V10 BEGINS at 3000 RPMs and climbs like a frieght train up to about 4500 RPMs...that is the TRUE power band of the V10...
I posted the HP/Trq curve of the V10 a number of pages back...you can see the HP climbs very steadily over the full RPM range and the Trq is very flat between about 2000 and 4000 RPMs and falls off after 4000 RPMs...
Keep that V10 in that band and she runs and pulls like a scalded dog.
joe.
Old Jan 5, 2011 | 12:02 PM
  #10413
RUFFSTUFF's Avatar
RUFFSTUFF
Originally Posted by plgebbia
As for the fuel pressure issue, Powerstrokes have been injecting fuel at about 25,000 psi for 17 years, and have had almost no issues regarding the high pressure injection.
Yes, your concern about the turbo bearings can be an issue, but if you shut it off accidentally, just turn it right back on.
Yeah, those concerns would appear to be valid if we were talking about a brand new engine design or concept in turbo charged diesels... but in the case of the big three, they've been doing it for a little bit, y'know?
Old Jan 5, 2011 | 12:37 PM
  #10414
plgebbia's Avatar
plgebbia
Originally Posted by Krewat
Maybe you haven't been here long. Scroll down a few forums, and check out the diesel forums where HPOP failures and leaks, injector failures and all other sorts of "issues regarding high pressure injection" seem to crop up all the time.
I live in the 7.3 forum, and that is where 90% of my posting is.
My statement was true, there are very few issues with injecting the fuel at 25,000 psi. There are some issues with the HPOP system occasionally (mainly on the 6.0 ) but they are not very common.
I have worked on many powerstrokes, and have never needed to change an HPOP, sometimes to upgrade, but never "needed" to.
7.3 injectors, (and 6.0 if they are well maintained) last a long time.
I have had 300,000 plus on original injectors. norm is around 200k.
Old Jan 5, 2011 | 12:48 PM
  #10415
bill11012's Avatar
bill11012
Modular motor junkie
One hour at 80 MPH I use about 6.5 gallons.
A V10 with the smallest tank can still run 4 hours at 80.
I can run 5.
Old Jan 5, 2011 | 02:21 PM
  #10416
X_Hemi_Guy's Avatar
X_Hemi_Guy
I can run 5.
And my Excursion has one of the largest fuel capacities out there...44 gallons!!!...way longer than my wife and two daughters bladders can last...
Old Jan 5, 2011 | 05:41 PM
  #10417
Rugby3's Avatar
Rugby3
The true measure of distance between fuel stations!
Old Jan 5, 2011 | 05:45 PM
  #10418
Snowseeker's Avatar
Snowseeker
My 44 gallon tank feeding the 7.3 @ 70mph can outlast pretty much anyones bladder.
Old Jan 6, 2011 | 08:23 PM
  #10419
plgebbia's Avatar
plgebbia
Well, now it's who can drive longer on a tank of fuel
I got that V10 running (bad fuel pump) and I drove it.
Underpowered pile o scrap..... just joking.....
It was actually quite powerful after 3500 rpm.
Old Jan 6, 2011 | 09:24 PM
  #10420
2001400ex's Avatar
2001400ex
You talk to him to see if he is willing to pull it with your 7.3?
Old Jan 7, 2011 | 02:40 PM
  #10421
plgebbia's Avatar
plgebbia
Not yet, but I will be talking to him soon.
Old Jan 7, 2011 | 03:10 PM
  #10422
Kajtek1's Avatar
Kajtek1
I can run 5.
That would make 12.3 mpg. Who is going to buy that?
Old Jan 7, 2011 | 03:26 PM
  #10423
bill11012's Avatar
bill11012
Yes, 12.0-12.5 MPGs.
But I'm sure you know better. What am I really getting?
Old Jan 7, 2011 | 04:43 PM
  #10424
krewat's Avatar
krewat
FTE Leadership Emeritus
Loaded or unloaded?
Hey Bill, sometimes it's more fun just to ignore the
Old Jan 7, 2011 | 04:59 PM
  #10425
donovan's Avatar
donovan
The true distance between gas stations.
I have NEVER EVER made more then half a tank with my wife in tow. What really sucks is looking for a clean restroom. That adds hours to any trip.Bill is about right on the MPG at 80. I get about 12.x at that speed. I think that is the speed limit.Donovan
