Sponsored by: Real Truck
Gas vs PSD
Old Jan 7, 2011 | 05:04 PM
  #10426
krewat's Avatar
krewat
FTE Leadership Emeritus
Actually, doing 70-80 I get much better than 12, loaded with about 1.5K lbs in the bed. Usually in the 14-15 range.
Old Jan 7, 2011 | 05:18 PM
  #10427
Kajtek1's Avatar
Kajtek1
I see that a lot. When I say "80mph" that means in 5 hr I will cover about 390 miles or 78 mph.
Too often when somebody says "70-80" that means he sees 80 downhill and drives with the needle on 70, what makes actual 68 mph and average 65.
I don't know you Krewat (and Bill) that well. How long takes you to drive 500 miles?
Talking about restrooms. California on I-5 not only closed about 50% of rest areas, but on those that are still open they deleted paper towels, leaving only annoying air dryers that in cold weather can give you a flu.
I started carrying paper towels with me. Have toilet paper in my truck just in case as well.
Old Jan 7, 2011 | 07:16 PM
  #10428
RUFFSTUFF's Avatar
RUFFSTUFF
Air dryers = flu? Out of all the BS in this thread, I have now reached my limit! Where's my flag?!?
Old Jan 7, 2011 | 07:41 PM
  #10429
Kajtek1's Avatar
Kajtek1
It is exaggeration, but did you ever try on foggy, 45F morning spend 5 minutes under barely warm air trying to get your hands dry?
Old Jan 7, 2011 | 08:16 PM
  #10430
bill11012's Avatar
bill11012
Modular motor junkie
Loaded or unloaded?
Unloaded. Same avg speed gets me 7 towing and 10.5-11.5 with an empty trailer.
Hey Bill, sometimes it's more fun just to ignore the
I know, I really do ignore a lot of it too.
I'm talking about 80 MPH average speed.
You know, I never thought this:
Originally Posted by bill11012
What are the PSD's high points?
Would end up with this:
Old Jan 7, 2011 | 08:35 PM
  #10431
bill11012's Avatar
bill11012
Originally Posted by plgebbia
If an engine has a net torque of 457 ft.lbs, but a similar diesel has 600, the gasser can keep up, but only by using shorter gearing (tranny and rear end)
Point: the diesel is a more capable engine, but the gasser can be made to compete by "using a pipe on the end of a breaker bar" to get more leverage.
But the thing is the V10 CAN use a longer bar. The PSD can't becuase of its narrower RPM band. The PSD uses more force on a shorter bar, the V10 less on a longer bar. They will both do the same work, just not with the same gear and RPM.
Old Jan 7, 2011 | 09:24 PM
  #10432
Kajtek1's Avatar
Kajtek1
Ou yeah?
I did travel in lot of 3rd and 4th World countries. The worse had a bottle of water standing on the side of the throne, but it took California Burger King to make me wiping my behind with toilet seat cover.
Are we becoming 5th World?
So what do you use in such a situation?
Old Jan 7, 2011 | 09:28 PM
  #10433
Kajtek1's Avatar
Kajtek1
But the time they will drive on the tank is going to be quite different
Old Jan 7, 2011 | 09:30 PM
  #10434
bill11012's Avatar
bill11012
I check first and don't go if there is nothing there to use.
Worst case is shop towels out of the truck.
Old Jan 7, 2011 | 09:33 PM
  #10435
bill11012's Avatar
bill11012
Not if its a 6.4.
Old Jan 7, 2011 | 09:58 PM
  #10436
Kajtek1's Avatar
Kajtek1
don't recall seeing too many rest areas in TX. With CA closures it takes average 150 miles between the legal stops. Good luck in holding it
Old Jan 7, 2011 | 10:09 PM
  #10437
bill11012's Avatar
bill11012
Love's truck stops and What-A-Burger are always nice rest rooms.
I like to run a long time between stops anyway.
We have almost none. The same year they cut funding for that they raised it for DPS patrol cars and officer over time.
Old Jan 8, 2011 | 05:59 AM
  #10438
scraprat's Avatar
scraprat
Top Answer: 5
I would of thought with all of the tree hugging greenies in Cali that pulling to the side of the road dumping and dragging your ars like a dog would be ok. You would be giving back to the soil and saving a tree by not wiping.
Old Jan 8, 2011 | 07:12 AM
  #10439
bucci's Avatar
bucci
The whole arguement of the gasser using gearing to "make it compete" is on the same level as a diesel using a turbo to "make it compete". So there isn't a need for an explanation for the "longer bar" analogy.
Goes back to the argument of gassers say "take off the turbo" and the diesel guys say " to run the same gear". That's been beat to death already.
Old Jan 8, 2011 | 09:29 AM
  #10440
Snowseeker's Avatar
Snowseeker
I have had to use my own underwear once.
