Sponsored by: Real Truck
Gas vs PSD
Old Dec 8, 2010 | 05:38 PM
  #9931
RUFFSTUFF's Avatar
RUFFSTUFF
Originally Posted by bill11012
When they leave there radar on, I can pick them up 1/2 a mile away.
With some effort and some discretion, you can beat the good ones too.
Sure thing, and with current radar and lidar units with ranges over 1 mile, that 1/2 mile + response time + time to slow down your vehicle = nailed if you are the targeted vehicle.
Hell, I once had a cop clock me when I was on my motorcycle next to an 18-wheeler. I figured that with his distance to me, the dispersion of the radar would make me invisible, masked by the 18-wheeler. That is, until I looked up the capabilities of his particular model, and yeah, the new guns are badass. Thank goodness for No Contest pleas.
Old Dec 8, 2010 | 05:53 PM
  #9932
driximus's Avatar
driximus
Yes they just look to see who is moving the fastest and the new radars will give them the fastest objects speed. They have some pretty nifty stuff now days.
Old Dec 8, 2010 | 05:59 PM
  #9933
exiled's Avatar
exiled
Radar picksup the largest moving mass. Well largest object.
Ideally your detector picks up when they shoot someone ahead of you. I run a radar dector just to pick up the emt signals. I like to know I'm coming up on something or the other way around.
Old Dec 8, 2010 | 06:30 PM
  #9934
powerstroke72's Avatar
powerstroke72
Depends on the unit and capability of said unit. But that's topic for another thread.
Let's stay on topic with the V10 vs. PSD thread.
Old Dec 8, 2010 | 06:31 PM
  #9935
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by ChargersFanInCO
I'm outta' here.
Now if only .
Old Dec 8, 2010 | 06:34 PM
  #9936
RUFFSTUFF's Avatar
RUFFSTUFF
Not true any more. Current technology has worked around that old radar principle. And that's assuming that radar is being used...
Old Dec 8, 2010 | 06:35 PM
  #9937
RUFFSTUFF's Avatar
RUFFSTUFF
You don't really think the previous 600+ pages have been on topic now do you?
Hell, there's probably 20 pages on Bill blowing up a motor... there ain't a whole lot of anything vs. PSD in that. That's more like Bill vs. Friction, yet no one cried foul on that!
Old Dec 9, 2010 | 01:02 AM
  #9938
95_Dually's Avatar
95_Dually
FOUL!!!!!!!
Ok, I did it...LMAO
Old Dec 9, 2010 | 03:09 AM
  #9939
powerstroke72
Bill's adventure was still related to the original topic. Radar, radar detectors, evasion techniques, etc. are not. You can PM me directly if you want to discuss it further.
Old Dec 9, 2010 | 05:51 AM
  #9940
RUFFSTUFF's Avatar
RUFFSTUFF
Party Pooper.
Old Dec 9, 2010 | 08:41 AM
  #9941
exiled's Avatar
exiled
Hey Bill a benifit from a psd's low rpm/power curver is being able to have rpms left over for a down shift if needed. The ram vs f150 video and anther thread in the 6.0 section really brought this home to me. If the condictions at hand render me to low rpm I'm in my power curve but yet habe a lot of room in rpm range to down shift if needed.
Old Dec 9, 2010 | 10:16 AM
  #9942
David N.'s Avatar
David N.
In the video the F150, with a 3.73 rear, was in 3rd, but couldn't go to 2nd. With the same transmission, and a 3.73 or even a 3.55, a diesel couldn't go below 4th and maintain that speed.
With a 3.73 rear, the diesel would be turning about 2900 rpm in 4th. Shifting to 3rd would take the rpm to over 3800.
With a 3.55, it would turn about 2750 in 4th, and would go to almost 3650 in 3rd. While 3650 might not hurt anything, its beyond peak power, so it wouldn't be able to maintain as high of speed.
A gas engine has a much broader rpm range, and will be able to down shift more than any current diesel can.
Old Dec 9, 2010 | 11:02 AM
  #9943
exiled's Avatar
exiled
I guess you don't understand my point. For 1 my psd isn't hooked up to that tranny. Next in that video that f150 could not make its peak power for being stuck at 3600 rpm at WOT which eans it was doing all that it could. Yea real wide range of rpms there. The psd would be at home pulling the green out of grass. What is so hard to understand this. Haveing your power at higher rpms can put you in less than ideal situations.
If you want to demastrate how this works I'm willing to watch.
Most cases I've seen the gassers 2nd is the same as my 3rd. So that kinda doesn't make sense reaaly to me. Ok your in second and I'm in 3rd? Or even in 4th gaining speed. Now I now the 04s and above have the same tranny as me and I'm to assume their geared the same??? On that same token have the same mutlipliers. Makes for some really good math.
Old Dec 9, 2010 | 12:35 PM
  #9944
Kajtek1's Avatar
Kajtek1
Off topic, but how do you like the V1?
I have been wanting to get one, but its hard to justify the money when my $50 radio shack detector works so well.
Only time its let me down was laser, and the V1 is not going to save me from that either.
I invested in Valentine ONE after I got ticket when $150 Cobra gave me late warning. Drove about 4000 miles with both detectors side by side. They acted like from different planets. While Cobra was picking up CB, cellphones, military radars giving me late warning on police radars, the V1 was on the spot 80 % of the time. Bottom line -they seldom beeped at the same time.
V1 will sense the radar from a mile and will even catch the rays bounced off other cars. Display showing direction of the rays as well the number of the beams helps as well.
This is my second V1 after the first one got stolen. V1 is registering the serial numbers and if my stolen pops up for upgrade or repair -I will know about it.
Got my $400 back several times.
Now, what dispute what is on topic, what not has to do with V10 vs PSD?
Old Dec 9, 2010 | 12:51 PM
  #9945
Kajtek1's Avatar
Kajtek1
Originally Posted by Fishin76
1 to 2 hours of following a v10 at speeds above 80 is probably around 6 - 8mpgs at best. 8mpg x 36 gallons (big tank) = 288 miles / 80 = 3.6 hours 324 / 90 = 3.2 hours 6mpg x 36 gallons = 216 miles / 90 mph = 2.4 hours and that's to 'side of the road' empty.
Thanks for spelling it out for me. I was trying to make V10 owners thinking, but looks like I failed miserably
