Sponsored by: Real Truck
Gas vs PSD
Old Dec 6, 2010 | 08:34 PM
  #9841
exiled's Avatar
exiled
Originally Posted by David N.
I don't mean for it to seem like I'm picking on you or anything. You're just posting quite a few things I want to comment on.
As far as math problems, I've posted a little (at least some equations), but I've done a lot more checking stuff. I'm not at all afraid to post stuff, but from my experience, when most people see lots of numbers, their eyes glaze over and they zone out until the next post anyway. Unless you want video from a Thunderbird with a 2V 4.6, I have nothing to offer there. I found this thread looking for info about the different engines.
I was really hoping that you would post the numbers including a rear end gear. Using those, the 5.4 would come out slightly ahead for peak torque in 1st, but not in other gears. But that was leading to another point, more about transmissions than engines, though. When comparing 1st in a manual to 1st in an automatic, people seem to leave out the torque converter and torque multiplying characteristic. I think multiplication peaks at stall speed and drops from there, but that is a big difference in getting a load moving initially. I think the converter multiplies 1.8x in the 5r100, which also happens to be roughly the ratio between 1st gears in the manual and automatic that is offered in these trucks. Coincidence?
By no means do I feel picked on. Like I said I had reasons I left the axles out. There's other numbers at play here I just don't know what are. Manuals have heavy flywheel cause they don't multiply tq so the tall first gear is really a small step when you concider what the torque converter multiples then the 1st gear multiplier. I know of 2 torque converter multiplier for the 5r110. 2.5x and 1.8x. I don't know which one it is etc. Even if we use 1.8 and the TS's 1st gear is 3.2 that comes to 5x is 1st gear. Josh's advantage if there ever was any is none.
Old Dec 6, 2010 | 08:45 PM
  #9842
exiled's Avatar
exiled
Originally Posted by monsterbaby
FWIW, my SD 7.3 scab long box 4x4 came across the scale this week at 7500
My crew FX4 8' bed 6.0 comes @79620 but I have a tool box. Of I remember right it sits @ 76?? Without it.
I posted that xause earlier it asked and never answered
Old Dec 6, 2010 | 08:51 PM
  #9843
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by ChargersFanInCO
yes/no; happy?
When I read things like that from you, you know what word comes to mind?
They don't run every engine up that way. If they did, then you bought a used engine in your new truck. Do you understand that? yes, or no?
Yes, I understand that. We are talking about the tests Ford did when they designed them. Not what they did to every V10 that came off the line.
I can see (for instance) an Eco-Boost being pulled off the line and being repeatedly dogged in different tests. I would hope it passed as it's brand new. I'd like to see them take one that's been driven by Billy Bob Redneck for 5 years and do the same test. 10:1 says it would blow up.
As long as Billy Bob did the most basic care during that 5 years, it should not have any trouble doing the same tests.
Are you under the severely misguided belief that EITHER of your V10's is as strong and stable as it was the day it rolled off the assembly line?
Well, the one spent a large part of its life with sludge for oil, so it has no hope. You already know that though.
The one that I have worked so hard, but also done all the maintenance on?
It should have no problem doing anything it could new.
Old Dec 6, 2010 | 11:46 PM
  #9844
Sand_Man's Avatar
Sand_Man
Along those lines, my '04 crew cab/sb V10 weighs in right at 7,000 with 1/2 tank gas and it has a shell that likely weighs 300 lbs (?). Is there that much of a difference between the PSD and V10 engines as far as weight?
Old Dec 7, 2010 | 12:07 AM
  #9845
ChargersFanInCO's Avatar
ChargersFanInCO
Of course...an engine would never just wear out...It can always be traced back to a lack of maintenance, right? I'd like to see you pull your other engine and run it through the same tests...$20.00? Awwww...scratch that, I'll offer you $50.00 to do it. Maybe 200140ex will match my oh-so-generous offer
Old Dec 7, 2010 | 12:14 AM
  #9846
ChargersFanInCO
^That's one heavy truck...lol My 09 is 7723 wet. Not much heavier than my 08 F150 was.
Old Dec 7, 2010 | 12:20 AM
  #9847
bill11012's Avatar
bill11012
The same test that blew my first one? I already did that.
The way Ford tested them? I would rather not, thats enough to take a brand new engine and just about wear it out.
It would need an overhaul after that.
Old Dec 7, 2010 | 12:28 AM
  #9848
ChargersFanInCO
No, you didn't go 20 minutes...but not that test... I'm talking about pulling your engine, hooking it to a dyno, and running it full tilt for however long Ford does, then shocking it with cold water, lather, rinse repeat, or whatever they do. That test. Your engine WILL do that, right? I think you said it can, so prove it. And before you say something like "pull yours and run it next to mine", the answer is "no" because I never claimed mine could do that...and if they did test diesels that way, at 8 months and 18000+ miles, I doubt mine would pass anymore.
Ahhh...you edited while I was typing....yes, the ford testing...
Old Dec 7, 2010 | 12:43 AM
  #9849
exiled's Avatar
exiled
^That's one heavy truck...lol My 09 is 7723 wet. Not much heavier than my 08 F150 was. Seriously, like 100lbs heavier, and with roughly 50hp and 300lb/ft of torque more.
You did notice the 7600lb empty right. 7900 lb is with tool box.
Old Dec 7, 2010 | 09:07 AM
  #9850
tgreening's Avatar
tgreening
Man, where did you guys get these skinny trucks? Mine weighs 9,400# with a full bag of diesel and me and nothing else.
Old Dec 7, 2010 | 09:11 AM
  #9851
ChargersFanInCO
I know it was a typo, but you wrote 79620 as the weight with the toolbox. that would make it one heavy truck.
Old Dec 7, 2010 | 09:12 AM
  #9852
ChargersFanInCO
Mine is a 250.
Old Dec 7, 2010 | 09:15 AM
  #9853
Fishin76's Avatar
Fishin76
I took my SD across the scales the other week at the scrap yard. 7360 with me and 1/4 tank of fuel...
Old Dec 7, 2010 | 09:18 AM
  #9854
Fishin76's Avatar
Fishin76
Our 7.3l's wouldn't survive the ford tests now either, so whats the point of asking bill to do it to his v10?
Old Dec 7, 2010 | 09:29 AM
  #9855
STOFFERJ's Avatar
STOFFERJ
interesting thread...
