Sponsored by: Real Truck
Gas vs PSD
Old Dec 6, 2010 | 05:50 PM
  #9826
phillips91's Avatar
phillips91
Originally Posted by ChargersFanInCO
lol...that was my post talking about eyeballing the weight and type PSD's, and exile talking about "Did the other guy know he was racing"?...You were probably in the land of oxy-buzz.
It was your post, but I was just letting him know that I agreed with him and psd side on that part of the argument, which is why I didn't come to the gassers defense. There are too many variables in determining how much a trailer weighs, what kind of engine the truck has, whether the other driver knew he was supposed to keep up with you, etc.
Originally Posted by exiled
I actually meant from a dead still, or going down the highway like in the ram and Ford video. Will your 5.4 take off and leave it? I'm not taking on paper or trick work outs. Just simple nose to the ground back breaking work. Why I ask is because depending on what year and what unit its put in the HP where fairly close between the 2. The overwhelming difference is the 7.3's tq. Not getting on the tq kick I just don't know what 5.4
From a dead stop, yes, my 5.4 will still walk off and leave my 7.3. The 7.3 is stronger for the first idle-3,000 rpm(0-12 mph), but my 5.4 will pass it before it hits 2nd gear(at 25 mph).
Old Dec 6, 2010 | 05:58 PM
  #9827
krewat's Avatar
krewat
FTE Leadership Emeritus
Approaching the line...
Old Dec 6, 2010 | 05:59 PM
  #9828
exiled's Avatar
exiled
So once they get going down the road a piece tje 7.3 regains the strong side. Are you saying your 5.4 is stronger, walking off 12-25 mph then tapers off. Is that saying the 7.3 has the upper hand under 12 and over 25?
  #9829
bill11012's Avatar
bill11012
Modular motor junkie
Chargersfan, you must have missed this both times I said it.
Originally Posted by bill11012
It was a yes or no question.
Do you understand the way Ford tested them or not?
Its been three days, and all I want is a simple yes/no.
Old Dec 6, 2010 | 06:11 PM
  #9830
phillips91's Avatar
phillips91
No, the 7.3 has the advantage from 0-12 and then from 12-whatever the 5.4 has the advantage. From 0-12 they are in the same gear at the same rpm, so the 7.3 has the advantage. After that, the 5.4 is always one gear lower and turning more rpms. Once my 5.4 passes it, the 7.3 isn't catching back up. From a line them up and go, top the hill the fastest, 0-60 or any comparison involving nothing but power I would take the 5.4 any day of the week. That is pulling the same trailers on the same hills on the same day.
Old Dec 6, 2010 | 06:14 PM
  #9831
ChargersFanInCO's Avatar
ChargersFanInCO
For joking with another mod?
Old Dec 6, 2010 | 06:15 PM
  #9832
ChargersFanInCO
yes/no; happy? They don't run every engine up that way. If they did, then you bought a used engine in your new truck. Do you understand that? yes, or no? You may have 2 "Friday Engines" for all you know. I can see (for instance) an Eco-Boost being pulled off the line and being repeatedly dogged in different tests. I would hope it passed as it's brand new. I'd like to see them take one that's been driven by Billy Bob Redneck for 5 years and do the same test. 10:1 says it would blow up. Are you under the severely misguided belief that EITHER of your V10's is as strong and stable as it was the day it rolled off the assembly line?
Old Dec 6, 2010 | 06:44 PM
  #9833
krewat's Avatar
krewat
You can PM me directly if you want to know what I meant.
Old Dec 6, 2010 | 07:21 PM
  #9834
exiled's Avatar
exiled
Cool. We must be talking a 3v 5.4l here. I wish I could find one with the manual. Btw FWIW just weighed my father in laws SD 5.4 4x4 scab. 7140
Old Dec 6, 2010 | 07:28 PM
  #9835
monsterbaby's Avatar
monsterbaby
FWIW, my SD 7.3 scab long box 4x4 came across the scale this week at 7500
Old Dec 6, 2010 | 07:33 PM
  #9836
David N.'s Avatar
David N.
David I'm going to combine both my replies here cause I'm on mobile and haven't figured out how to put more than 1 quote in a post.
I've defended the 5.4 and the 6.8. I've strived very hard to prove that my psd has it's mark in the towing world and that neither gasser will out tow my psd. This is very hard for me cause I'm pretty dumb and even dumber with words.
I believe I was the first to say that the badges could be seen. Not a gasser. Unless a post slipped in while I was typing. I try to keep everything 1:1 as possible. I try very hard to correct my mistakes and things that I've said that was wrong or explain myself better. I don't see you exposing your self doing math problems or making video to support what you say.
I left the axle out because the engine and tranny in the 2 trucks is unchangeable. I don't know if you could order the 4.10 in the 6.4, but you could most certainly put it in after buying the truck. What's says you now. I have 4.11 in my truck. In 04 you had a quite a few rear gears to chose from.
The 1 thing that nobody points out about tractive force is that when we start out I'm working in my max tractive force. Its very easy to achive. The gasser has to rev up to or dump the brake or clutch in his powerband. We know what will happen. He'll either lunge and slip when he jerks the trailer or slip as soon as the power is sent to the rear. Which means - tractive force. This formulas is meant to find the maxium pulling power a system CAN reach. It doesn't mean it WILL reach it.to many factors hinder it.
I don't mean for it to seem like I'm picking on you or anything. You're just posting quite a few things I want to comment on.
As far as math problems, I've posted a little (at least some equations), but I've done a lot more checking stuff. I'm not at all afraid to post stuff, but from my experience, when most people see lots of numbers, their eyes glaze over and they zone out until the next post anyway. Unless you want video from a Thunderbird with a 2V 4.6, I have nothing to offer there. I found this thread looking for info about the different engines.
I was really hoping that you would post the numbers including a rear end gear. Using those, the 5.4 would come out slightly ahead for peak torque in 1st, but not in other gears. But that was leading to another point, more about transmissions than engines, though. When comparing 1st in a manual to 1st in an automatic, people seem to leave out the torque converter and torque multiplying characteristic. I think multiplication peaks at stall speed and drops from there, but that is a big difference in getting a load moving initially. I think the converter multiplies 1.8x in the 5r100, which also happens to be roughly the ratio between 1st gears in the manual and automatic that is offered in these trucks. Coincidence?
Old Dec 6, 2010 | 07:36 PM
  #9837
RUFFSTUFF's Avatar
RUFFSTUFF
Too much bravado, too little brains and absolutely no opportunity to do anything about either. Yes, it's an internet forum... Please continue...
Old Dec 6, 2010 | 07:45 PM
  #9838
David N.'s Avatar
David N.
If you're going to quote or paraphrase me, you need to get it right. I called BS on it because it was a LIE from the get go. Hook up the same trailer to a V10, and one to my 6.4, and that V10 is NOT going to pass me if I'm giving it all its got. After several other posts, it turned into the badges, but that was after the 3 "I can tell by the tailpipes" crap...Once I pointed out you can;t see the tailpipes if there's a trailer behind the truck, then it focused on the badges, and I still call BS on that. Mine look black sitting in my driveway. Of course, my truck is red though. If you fail to believe that, then look at the pic on my profile. Also, learn how to READ because the guy never said "they were 6.4 diesels". He said one was a 6.4 and the other a 6.0.
Peak horsepower is what counts toward top speed. The 3V V10 and the 6.4 are very close in peak hp, so they should have close to the same top speed for a given load. However, with different gearing, there could have been a situation where the V10 was right at peak hp at the top speed both could pull, but the 6.4 was several hundred rpm below peak hp. If that was the case, I think the scenario is completely feasible.
I think you had already pointed out the exhaust being hidden when I posted, or I would have. Even without a trailer, I think it would be hard to see.
As far as the badges, from the pictures of your truck, I think Ford put the wrong ones on yours. Either that or you have a gas truck with custom exhaust. Seriously, though, on most colors other than red, its easy to see the difference.
Old Dec 6, 2010 | 08:10 PM
  #9839
David N.'s Avatar
David N.
A couple of nice graphs from a spreadsheet would show what you're trying to say so much easier. If only we could find some comparable dynos.
Old Dec 6, 2010 | 08:12 PM
  #9840
ChargersFanInCO
Why would you say that? My badges have the red mesh. They just don't look like it from more than about 5' away, which is what I said. You (I believe you were in on it) and several others said you can see the difference from a long way away. I specifically looked at it today on the way out of Sears and couldn't see the red until I was right up on it...again, due to the angle of the sunlight. I have a 6.4 PSD, not a gasser with a custom exhaust.
Seriously though, if the sun is at any angle other than right on them, it's not that easy to see. It's a plastic, 1/3" mesh so it's very susceptible to shadowing...We have very few gassers up here though (think altitude) so I haven't seen a true black one yet that I know of.
