Sponsored by: Real Truck
Gas vs PSD
Old Oct 19, 2009 | 03:51 PM
  #2431
95_Dually's Avatar
95_Dually
Originally Posted by Krewat
How many production aluminum-headed 302/351W's?
Maybe I should have been more specific, but I was comparing the modulars to other aluminum-head motors. Not iron-head production slugs
GM doesn't have a problem. Dodge, Toyota, Honda and the list goes on, don't have problems. The new V-10 doesn't shoot out plugs either. Sounds like VW and 2v V-10 are related somehow.
Old Oct 19, 2009 | 03:52 PM
  #2432
phillips91's Avatar
phillips91
I was comparing the modulars to every ford small block v8 from 1962 until 1996/97. That's 35 years of trouble free spark plugs. What's the modular on now, 13 years(with some limited production starting in 91)? 9 years that couldn't keep the plugs in and 4 years you can't get the plugs out?
They haven't been production, but I've owned several aluminum headed mustangs and have yet to blow a plug out of them. The other brands haven't had any problems with their aluminum heads either. So it must not be the aluminum that's causing the problem. It's probably the combination of the aluminum and the lack of threads. Or in other words, a design flaw
Old Oct 19, 2009 | 03:54 PM
  #2433
95_Dually's Avatar
95_Dually
But that is in the past. Now we move on to newer smog laws and restrictions. Yippee
Old Oct 19, 2009 | 03:55 PM
  #2434
phillips91's Avatar
phillips91
It's quitting time for me guys. You all have a good evening and don't beat on each other too badly while I'm gone
Old Oct 19, 2009 | 03:57 PM
  #2435
95_Dually's Avatar
95_Dually
Awe man, now I have nothing to do.
Old Oct 19, 2009 | 03:58 PM
  #2436
95_Dually's Avatar
95_Dually
That's ok. I ran out of popcorn!
Old Oct 19, 2009 | 04:10 PM
  #2437
ken kenmnedy's Avatar
ken kenmnedy
OK boys its all as easy as this...... a superduty is a superduty is a superduty.....gas or oil v8 or v10 they all get it done!!!!!!!
Old Oct 19, 2009 | 04:52 PM
  #2438
95_Dually's Avatar
95_Dually
What he said
Old Oct 19, 2009 | 05:28 PM
  #2439
krewat's Avatar
krewat
FTE Leadership Emeritus
Using the logic of previous posters in this thread, there would be no spark plug insert kits available if there wasn't a problem.
Look up Timesert, they have kits for BMW, Chevy (including the LS motors), Toyota and Honda ++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair, I suspect Dodge can use a standard generic insert.
I was using a VW tech's experiences as an example of how other manufacturers also have spark plug problems. They do exist.
Old Oct 19, 2009 | 06:29 PM
  #2440
95_Dually's Avatar
95_Dually
Thread inserts were developed a long time ago and are also used in cast iron heads. Sometimes mechanics screw up and cause problems like this. Thread inserts or helicoil's are used in many areas not just on spark plug holes.
This is pretty funny how the factory heads blowing sparkplugs and people stripping or cross threading bolts or sparkplugs are the same issue. I don't know.............
EDIT: I have not heard of any other motor launching sparkplugs except for VW which I just learned today.LOL
Old Oct 19, 2009 | 07:29 PM
  #2441
Lead Head's Avatar
Lead Head
Like it was mentioned, blowing plugs is not a characteristic of aluminum heads, its a characteristic of poorly designed aluminum heads.
Virtually every small engine since the mid 50s has had aluminum heads, and I don't hear about them blowing sparkplugs out. I've seen lawnmowers with less-then-finger-tight sparkplugs still running happily and no sign of the threads being stripped out. All of the new fancy OHV V-Twin small engines running 9:1 compression don't eject plugs. I don't see tons of dirt-bikes, four wheelers and motor cycles shooting plugs either. My Honda XR200 has about 12 "threads" on both the plug and the head to hold it in, the original 2 valves had what? 4-5?
Old Oct 19, 2009 | 08:49 PM
  #2442
mudmaker's Avatar
mudmaker
Man after reading the last couple of pages I sure am glad I don't have spark plugs!!LOL!
Old Oct 19, 2009 | 10:13 PM
  #2443
95_Dually's Avatar
95_Dually
Originally Posted by mudmaker
man after reading the last couple of pages i sure am glad i don't have spark plugs!!lol!
rofl!
Old Oct 20, 2009 | 08:03 AM
  #2444
phillips91's Avatar
phillips91
No one is saying that no other car on the road besides the triton has ever blown a plug. Sometimes people who should never even open the hood of their vehicle try to change plugs and cross thread them, don't tighten them good enough, etc, and they blow a plug. I said the modular is just MORE PRONE to shooting plugs and that even factory trained technicians have problems getting the plugs in correctly(if the plug shooting is caused by improper installation). Go to the modular forum and look up blown spark plugs and see what you get. Dozens of threads with hundreds of people complaining about it happening to them. Go to yahoo and a search for blown plugs. 9 out of 10 sites that come up are about the modular. Consumer affairs has over 300 pages of people saying it happened to them. You can search the entire forum here and you won't find as many blown plugs in every group combined as you'll fine in ONE thread in the modular forum alone.
In the 4.6/5.4 section someone posted a poll wanting to know how many have had a plug blow out. 52 of the 159(32%) people responding said they have had it happen, and that was just 4.6 and 5.4 owners and didn't count multiple blown plugs. That's a very high percentage for that many of voters. Some of those people have had 3 or 4 plugs shoot out on the same engine. It's not something that's going to happen to every single engine or anything, but it is something that happens at a much higher frequency than on other engines.
Old Oct 20, 2009 | 08:10 AM
  #2445
Johnny Langton's Avatar
Johnny Langton
The same can be said about the 6.0L and head gaskets,yet the diesel guys all argue that it's not a problem,and it's isolated to certain years,etc.
JL
