Sponsored by: Real Truck
Gas vs PSD
Old Dec 11, 2010 | 09:59 AM
  #10051
Snowseeker's Avatar
Snowseeker
But the PSD sounds much better!
Old Dec 11, 2010 | 10:32 AM
  #10052
Tom's Avatar
Tom
Originally Posted by 2001400ex
Because the 7.3 was smoking at the end...the entire pull was not all uphill, so it is more accurate to just use the first hill.
Though doesn't the v10 programmed have more hp than the 6.0?
Possibly, but I'm not sure. Mike's V10 has 310 HP stock, but tuners don't often make much more power on gassers compared with a diesel. Something to do with forced induction...
Heck yes it does! That 7.3L had straight pipes going out to twin stacks in the bed...this thing was the loudest truck I have ever driven!
Old Dec 11, 2010 | 10:54 AM
  #10053
driximus's Avatar
driximus
Originally Posted by bill11012
Send me a PM the week before and we can try and get togather.
I will have the engine problems solved in the 01 long before then.
Sounds like a plan we will have to get some beers also!
Old Dec 11, 2010 | 11:51 AM
  #10054
Fishin76's Avatar
Fishin76
Originally Posted by Crazy001
Possibly, but I'm not sure. Mike's V10 has 310 HP stock, but tuners don't often make much more power on gassers compared with a diesel. Something to do with forced induction... !
You even said you took it easy on the psd, so as not to break it. I heard many times where you backed out of the psd, and didn,t run it as hard as the V10, hard to compare the whole run when it was driven differently.
Old Dec 11, 2010 | 12:08 PM
  #10055
Tom's Avatar
Tom
Yeah, I wish we were able to run that one more than once. That would have settled this nicely .
Of course I'm still more of a diesel guy; I'm on my second PSD and never have owned a V10. Almost did, but I really got used to the way my 6.4L towed my trailer and was afraid I wouldn't be as happy with a V10.
And with the fuel mileage I'm getting on my 6.7L I couldn't be happier.
Old Dec 11, 2010 | 01:06 PM
  #10056
2001400ex's Avatar
2001400ex
The stock 6.0 has 325. I would imagine the programmer at a minimum got him to 325. Post the video of how the 6.0 pulled that hill with roughly equal hp.
(Yes the haters will talk about the transmission difference. Haha)
Old Dec 11, 2010 | 07:04 PM
  #10057
bill11012's Avatar
bill11012
Modular motor junkie
Get an 05+ V10 to compare to the 6.0.
The 2V V10/4R100 will not run like a 6.0/TorqueShift.
Old Dec 11, 2010 | 07:11 PM
  #10058
driximus's Avatar
driximus
Next time one of these tests go around we need to schedule a Dyno also get an Idea of how much HP and Tq is getting to the ground. This way we can Ideally run a Diesel with roughly the same HP to the ground as the V-10 as part of the deal.
I will run mine also but I want to do a run with the juice turned up just for ****s and giggles.
Old Dec 11, 2010 | 07:15 PM
  #10059
bill11012's Avatar
bill11012
I won't be 21 until 2013.
Sounds good to me. How much do a few dyno runs cost?
I have never priced it.
Old Dec 11, 2010 | 07:18 PM
  #10060
driximus's Avatar
driximus
sucks to be you ill get you some Root brewskies. Ill pay because I feel sorry you are driving a V-10
Last time I ran i got 3 for 40ish dollars however that was on a Dyno day so the operator had more volume to lower the price. I cant imagine it being to much more though.
Old Dec 12, 2010 | 08:47 AM
  #10061
Sand_Man's Avatar
Sand_Man
There's a local shop here with a chassis dyno and he charges $175 for one hour. If he only charged $40 there'd be a line around the block to get in!
Old Dec 12, 2010 | 09:44 AM
  #10062
Snowseeker's Avatar
Snowseeker
We have a local shop with a dyno that holds a dyno day once a year. $35 for 3 pulls. AWD dyno no less.
Old Dec 12, 2010 | 05:12 PM
  #10063
phillips91's Avatar
phillips91
I don't know, my buddy's 1994.5 (really 1995), pulls pretty good, with about 130,000 miles on it. He has a manual, but it pulls my camper the same speeds as my 6.0 did.
My 7.3 pulls pretty good too. I never said it didn't. I just said that if you aren't afraid to run it over 3,000 rpm the 5.4 will outpull it.
Originally Posted by monsterbaby
I owned an expy with a 5.4 and the same gears and it pulled my trailer and race truck darn good, on flat ground and around town I would say VERY comparable to my 7.3 but on a hill it wouldn't even touch the PSD.
White breast hill locally, the SD with the same trailer would pull the hill on cruise and never drop more then 1mph, the 5.4 would drop over 5 adn down shift.
You are saying the same thing I have been arguing. On flat ground my 5.4 does just as good as my 7.3, but on hills the 5.4 has to downshift. Yours may have dropped 5 mph before it downshifted, but I bet if you weren't afraid to press the gas pedal and turn some rpms it would have more than made that 5 mph up. Downshifting and having to turn more rpms doesn't make an engine a dog or weak.
Originally Posted by ChargersFanInCO
My 2008 5.4 (it was an automatic) with 300/365 was a DOG...maybe it was the altitude though. Night and day between my PSD and that engine.
Going up Vail Pass you are looking at 33% hp loss with a gasser. That would put your 5.4 at 207 hp. That is on par with the old 5.0. Being an f150 it probably had 3.55 gears too.
Originally Posted by exiled
Granted I don't know what tranny you have in your 97. If it had the 4r100 the with the tq converter its 1st gear is 5.2x 425 which is 2210 lbs @1600rpm Your 5.4's first gear is 5.7x 350 which is 1995 lbs at ?3800rpm? Now who has 1st gear at vantage? Now you step up to a 6.0's power rateings= no prayer. I know with a stick you wanna hold the power band. I can shift my tranny up manually.
My 7.3 has a manual with the same gear ratios as my 5.4 and turns half the rpms. The 7.3 makes peak tq at 2,000 rpm, not 1,600 and the 5.4 makes peak tq at 2,500 rpm and not 3,800. You also have to remember that even if it had an automatic (which it doesn't), the tc is only multiplying the tq for a very short period of time. It doesn't multiply it all the way through the entire gear. By the time my 5.4 hits 4,500 rpm (303 tq) my 7.3 has shifted to 2nd and is at about 2,000 rpm (425 tq with a 2.93 ratio). Those numbers are 1727 for the 5.4 and 1245 for the 7.3. That is why I said that as soon as my 7.3 shifts to 2nd the 5.4 runs it down and passes it in a hurry.
Originally Posted by tgreening
Now don't go bringing pertinent real world experience in here. That just won't do. Stick to calculators and arm-chair engineering.
You must have missed the part where I said I own both vehicles and pull the same trailers on the same hill with both of them. I just don't mind downshifting or turning rpms in mine.
If you listen to what is be said. the 7.3 topped first hill at 25.
Now, running the V10 with a tune, 20 at the top of the first hill.
Here is my 5.4 with the same amount of weight on a shorter hill that is a 23% grade. I topped the hill at 35 mph after letting off to go over road construction and to go around a turn. The v10 in the video didn't have the gearing off the line to get the engine up to peak power on the hill. Having the manual tranny in mine with the low 1st gear actually allowed my engine to rev to a point that it was making more power than his v10.
YouTube - 5.4 pulling 11,200 lbs up 23% grade
Like I said above, the v10 had the peak power, but it didn't have the gearing or low end tq off the line to get the load moving to where it would reach peak power. The rpm he peaked at on the hill would have it making less than about 240 hp(less than a 2v 5.4). A 4r100 and a 3.73 is quite possibly the worst set up for a test like that. Put a TS or a manual and 4.10's behind it and it would have made a world of difference.
Old Dec 13, 2010 | 06:16 AM
  #10064
2001400ex's Avatar
2001400ex
Doesn't matter, how many times have you guys said "well the v10 has 6 more horsepower so it will outpull the psd regardless of torque, just rev it to 5k."
Haha
Old Dec 13, 2010 | 01:07 PM
  #10065
bill11012's Avatar
bill11012
Haha
How is such a small amount of power going to make up for bad gearing?
