Sponsored by: Real Truck
Gas vs PSD
Old Dec 7, 2010 | 06:39 PM
  #9901
exiled's Avatar
exiled
Originally Posted by bill11012
His 7.3 is an OBS. 215HP
What's an OBS? I'm going to wait and confirm that before I say something.
Old Dec 7, 2010 | 06:44 PM
  #9902
bill11012's Avatar
bill11012
Modular motor junkie
Old body style. The 97 and back trucks, before the SuperDuty came out.
Old Dec 7, 2010 | 06:55 PM
  #9903
ChargersFanInCO's Avatar
ChargersFanInCO
Yes, becuase that was the only logical option. You said you had "no choice". I was merely pointing out that you DID.
It can and will run for days on end at WOT. And no, I'm not going to prove it.
They can do it for 8,000 hours, so I'm pretty sure mine could do it for 12. No it can't. If it could, you'd prove it, and since you can't prove it, it can't do it. It's the same thing as "No pics, it didn't happen".
I have no problem with you NOT going out and blowing up your other truck. Really. I have no problem with the V10 either. (remember that Krewat) I have a problem with people making false claims about the V10, and acting like its the premier engine from Ford. PSD's outsell the V10 what, 8:1? I'm sure if the V10 was the better choice for the haulers, we'd all be driving V10's. Hell, a PSD is a better choice even for long distance driving without a load.
Take care of your V10. I'll take care of my PSD.
Old Dec 7, 2010 | 07:04 PM
  #9904
exiled's Avatar
exiled
That pretty much sums up the last 100 pages.
I can see you feeling that way. I think a lot has came out over the last 100 pages. I think its been a good stride. I've learned a few things.
Old Dec 7, 2010 | 07:07 PM
  #9905
ChargersFanInCO
lol...so have I.
Old Dec 7, 2010 | 07:19 PM
  #9906
phillips91's Avatar
phillips91
This I'm going to have to see. What's the multiplier on the torque converter on the 4r100? 2.5x sound right? The hps are running close to the same the 7.3 might be higher. I'm thinking you have a 2000 7.3, which I believe has 275hp 45lbtq. Up tell 03 the 5.4l was looking at 260 hp and 350 lbs tq.
With no mutipling from the engine you have no advantage in 1st then get dogged out in gear after. I might have totally missed something here. I know you school me and I expect nothing less. I want to learn as much as I can.
Like Bill said, my 7.3 is a 97 model that is 225 hp and 425 tq. My 5.4 is 260 hp and 350 tq. My point in comparing them is to show that an engine with 75 less tq but more hp and the ability to hold a gear twice as long can use that gearing advantage to pull a load better/easier/faster/etc. If we are still able to get together I would be more than willing to go up against a stock SD 7.3 with an auto if one wants to come along.
Old Dec 7, 2010 | 07:34 PM
  #9907
2001400ex's Avatar
2001400ex
I don't know, my buddy's 1994.5 (really 1995), pulls pretty good, with about 130,000 miles on it. He has a manual, but it pulls my camper the same speeds as my 6.0 did. In other words, limited by the corners more than anything. The only problem he had was his last trip to the dunes towing his Jeep by the bumper with its 38 inch tires. But there was so much drag, it was actually harder to pull than my camper (another reason why judging by "looking" at the trailer is dumb).
Anyways, Bill, I am glad to see you are backing off a little. Now you say it "probably" will rather than "it definitely" will. Haha
Old Dec 7, 2010 | 07:37 PM
  #9908
monsterbaby's Avatar
monsterbaby
if you weren't so far away I would take you up on that. I would even pull the chip or set it to stock your choice.
BUT it's still not totally stock, I do have a 5" exhaust and a slightly modified fuel system (regulated return instead of the factory dead head style) I owned an expy with a 5.4 and the same gears and it pulled my trailer and race truck darn good, on flat ground and around town I would say VERY comparable to my 7.3 but on a hill it wouldn't even touch the PSD.
White breast hill locally, the SD with the same trailer would pull the hill on cruise and never drop more then 1mph, the 5.4 would drop over 5 adn down shift. yes it was an automatic, and I know your claiming the stick makes all the difference, but since I have only seen 1 5.4 with a manual trans behind it, those are the exception and not the rule. Also that person sold it after 6 months and went back to a V10 cause it was a dog, couldn't pull his stock trailer with it.
Old Dec 7, 2010 | 07:47 PM
  #9909
ChargersFanInCO
My 2008 5.4 (it was an automatic) with 300/365 was a DOG...maybe it was the altitude though. Night and day between my PSD and that engine.
Old Dec 7, 2010 | 08:12 PM
  #9910
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by ChargersFanInCO
Actually, it didn't bother me at all...You've been doing it since I joined this thread, and it's easy to rebut. You, on the other hand TRY to keep pushing my buttons, hoping I'll say something bad so you can simply ban me. That's not going to happen.
That's not what I intend. Not at all. What I'm trying to do is get you to PARTICIPATE in the discussion instead of feeding it with misdirection.
Old Dec 7, 2010 | 08:27 PM
  #9911
krewat's Avatar
krewat
Ford's marketing target for the V10 was 14% of the total Superduty's produced in the 2000-2003 period if I recall correctly.
14% - .14 - that's just a about 1 in 7. But then you have to factor in the 5.4, and at the time, that was more than 14% I believe.
If Ford tells dealers that 14% of their stock should be V10's, guess what they order, and salesman tell people to buy?
Again, and maybe you will never ever get this - your "better choice" is better FOR YOU. Not for me, and apparently for lots of other people. I'm better off with a gasser. I get at or near 17MPGs on the highway. No gasser has to worry about water separators, multiple fuel filters, regens, urea, or a bunch of other things.
Now, stop beating that dead horse We KNOW that YOU don't think the V10 is the "right choice" for YOU. It IS however, the right choice for US.
Old Dec 7, 2010 | 08:32 PM
  #9912
ChargersFanInCO
Ok, for the last time...
Bill: My V10 can run at WOT all day.
Me: Prove it.
Bill: GRRRRR...Blew it up.
Me: (Didn't laugh at him) Try your other one.
Bill: No
Where's the misdirection you speak of? I'm done arguing this part.
Old Dec 7, 2010 | 08:33 PM
  #9913
ChargersFanInCO
I thought I saw (on here) 8:1 average. Oh well...It's more like 15:1 up here, but that's altitude related.
Old Dec 7, 2010 | 08:40 PM
  #9914
bill11012's Avatar
bill11012
Me: Prove it.
Bill: No
I did run the other one!
Old Dec 7, 2010 | 08:48 PM
  #9915
krewat's Avatar
krewat
Misdirection maybe the wrong word to use. All over the board, that might be more accurate.
I've said it before, and I'll say it again. Maybe you should back away from this thread for a few days, and maybe we'll all do the same thing.
100,000 wanting to see you blow up your other V10... Reality is the same 50-60 people posting again and again...
So a 5.4 SD and a PSD SD weigh about the same? I wonder why some people talk so much crap about how heavy a PSD is... I didn't realize the 5.4 made over 650lb/ft of torque...Boy, that thing is a monster. I sure hope I don't see one of those up here.
(I know...I'm just seeing how his pain pills affect his memory)
His 7.3 must run on 3 or 4 cylinders if it does. We've got some nice 7.3's around these parts. My 6.4 would eat his 5.4, but he doesn't believe that either....(Too many oxy's)
Bill, did you blow your other truck up yet? Did it freak you out when you dropped the pan and the oil pump pickup screen was still clean?
lol...that was my post talking about eyeballing the weight and type PSD's, and exile talking about "Did the other guy know he was racing"?...You were probably in the land of oxy-buzz.
yes/no; happy? They don't run every engine up that way. If they did, then you bought a used engine in your new truck. Do you understand that? yes, or no? You may have 2 "Friday Engines" for all you know. I can see (for instance) an Eco-Boost being pulled off the line and being repeatedly dogged in different tests. I would hope it passed as it's brand new. I'd like to see them take one that's been driven by Billy Bob Redneck for 5 years and do the same test. 10:1 says it would blow up. Are you under the severely misguided belief that EITHER of your V10's is as strong and stable as it was the day it rolled off the assembly line?
Why would you say that? My badges have the red mesh. They just don't look like it from more than about 5' away, which is what I said. You (I believe you were in on it) and several others said you can see the difference from a long way away. I specifically looked at it today on the way out of Sears and couldn't see the red until I was right up on it...again, due to the angle of the sunlight. I have a 6.4 PSD, not a gasser with a custom exhaust.
Seriously though, if the sun is at any angle other than right on them, it's not that easy to see. It's a plastic, 1/3" mesh so it's very susceptible to shadowing...We have very few gassers up here though (think altitude) so I haven't seen a true black one yet that I know of.
Of course...an engine would never just wear out...It can always be traced back to a lack of maintenance, right? I'd like to see you pull your other engine and run it through the same tests...$20.00? Awwww...scratch that, I'll offer you $50.00 to do it. Maybe 200140ex will match my oh-so-generous offer
^That's one heavy truck...lol My 09 is 7723 wet. Not much heavier than my 08 F150 was.
No, you didn't go 20 minutes...but not that test... I'm talking about pulling your engine, hooking it to a dyno, and running it full tilt for however long Ford does, then shocking it with cold water, lather, rinse repeat, or whatever they do. That test. Your engine WILL do that, right? I think you said it can, so prove it. And before you say something like "pull yours and run it next to mine", the answer is "no" because I never claimed mine could do that...and if they did test diesels that way, at 8 months and 18000+ miles, I doubt mine would pass anymore.
Ahhh...you edited while I was typing....yes, the ford testing...
Because Bill has REPEATEDLY said his can run WOT all day because "it was designed to do it".
I don't know if it would or not...I know I'm NOT going to do it. Does that clear things up for you?
8000hrs? Naw...How about 12hrs at WOT? Hell, you say you can do it, so show all of us just how BAD your V10 really is.
No it doesn't. I said I go up Vail Pass at 55-60, no problems, and the V10's are always in the truck lane with their flashers on. Are you confused about any other posts I've made? If you are, write them down and I'll address them when I return from Christmas shopping with the wife.
So you're saying you DID have a choice...
Oh yeah...that transfer case and front axle is the big weight difference. Isn't the engine just a few hundred pounds? Edit: looks like 450lbs difference or so for the engine depending on where you read...For that much more torque, I'll take it.
I didn't say both choices were desirable. I was merely pointing out that you had a choice when you said you had no choice.
Not necessarily...you would have been presented another set of choices had you stayed on the gas when you passed said trooper....
And that was a choice you made. You didn't have to outrun him. You could have made the choice just to keep screaming down the highway in 2nd gear if you wanted. Eventually, the trooper would have made a choice, and then you would have had more decisions (choices) to make. You merely CHOSE to start obeying the law again.
Now that that's out of the way, you have another decision (choice) to make: Are you going to take your truck out and PROVE you can run at WOT "all day" (I'll settle for 12hrs) or are you going to quit being silly and stop proclaiming that you can run your truck at WOT all day?
I think he's already out there doing it. He'll be back in a bit, connecting rods in hand (damn that sounds familiar) to tell us what happened.
Sure got quiet...I think he's out there again. Same feeling I had last time he did it.
