Sponsored by: Real Truck
Gas vs PSD
Old Dec 10, 2010 | 04:23 PM
  #10006
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by David N.
Ford seems to think it is.
FORD CLASS-EXCLUSIVE V10 GAS ENGINE, TORQSHIFT TRANSMISSION WILL POWER MEDIUM-DUTY CHASSIS CABS | Ford Motor Company Newsroom
Old Dec 10, 2010 | 04:38 PM
  #10007
Oxman504's Avatar
Oxman504
Originally Posted by Krewat
Since you're new here, let me try to explain the concept Bill hasn't explained well
Higher RPM range means you can gear the vehicle better to utilize that higher RPM. Gearing multiplies torque. A higher spinning V10 in a lower gear, or with a lower rear gear, can wind up putting more torque-to-the-ground at given speeds.
For instance, above, when I said the 7.3 is putting down 420 ft/lbs while the V10 is only around 360 or so, if you have 4.30's in the V10 and 3.73s in the PSD, the result is almost the same. 1548 for the V10 in 3rd (1:1 gear) and 1566 for the PSD in 3rd.
If you are lugging the PSD at 2000 RPM, and pull the V10 down into 2nd instead of third, the V10 can take the revs, and wind up putting much larger amounts of torque to the ground.
HP when towing
In certain circumstances, that means you could be pulling a hill with the V10 and running past a PSD that can't downshift because it doesn't have the RPM range the V10 does.
This can and does happen in the real world.
It comes down to likes and dislikes and how people like to drive, in the end.
The concept is the same in drag racing, high Rpm's with low gearing. Good for geting good 1/4 mile time bad for towing.
Why do you not see any GAS powered big rigs, because diesel fuel has more power per drop then gasoline. You need TQ more then HP when towing.
Old Dec 10, 2010 | 04:39 PM
  #10008
Oxman504's Avatar
Oxman504
Used the same rear gear in both trucks. 3.73 is good for light towing in the F-Series, but I'd rather have 4.10's best of both worlds.
Old Dec 10, 2010 | 04:50 PM
  #10009
Oxman504's Avatar
Oxman504
See now you are not comparing apples to apples. We were talking about taking a stock 1995 Powerstroke and V10(that was not medium duty for this year) with the same gearing.
If you want to use the 2011 Trucks well compare it to the 400HP 800TQ Scorpion Diesel motor.
Tell me that your V10 will out pull it.
Old Dec 10, 2010 | 04:55 PM
  #10010
krewat's Avatar
krewat
The only difference between the V10 they are going to put in F650 and F750 and my 2-valver is the heads. Crank, rods, block, everything else is the exact same thing.
There was no V10 in 1995. It started in 1997, in E-series, released mostly to fleets and motorhome manufacturers so they could work the bugs out. There were none. It was put into the 1999 Superduty which had been engineered from the get-go to be able to fit the V10 into it. It wouldn't fit in the OBS F-series. In 2000, it got PI (performance improved) heads like the rest of the modular engine lineup, in 2005 it got 3-valve heads.
Not sure where you're drawing the line between power differences, durability, or anything else for that matter
Old Dec 10, 2010 | 04:56 PM
  #10011
krewat's Avatar
krewat
Oh, and just for grins and giggles, the underhood sticker for my V10 says "Meets Federal ULEV specifications for heavy-duty truck engines for 2001" or some such thing. Note the "heavy-duty" part.
Old Dec 10, 2010 | 05:01 PM
  #10012
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by RUFFSTUFF
Should I use a different font? Maybe bigger letters? I like colors too...
Your trying to hard.
Old Dec 10, 2010 | 05:08 PM
  #10013
Oxman504's Avatar
Oxman504
Sorry typo 1997. Yes they only came in the E Series for that year I was just comparing year for year. Tell me where Ford states that their V10 will out perform their PSD year for year. Your telling me that Ford is overcharging it customers $5000 or better for the diesel option, that the V10 WILL out perform any PSD for the year both were made.
That's just ludicrous.
Old Dec 10, 2010 | 05:14 PM
  #10014
exiled's Avatar
exiled
Gas or diesel does not affect gear ratios in the transmissions. The 4R100, 5R110, and 6R140 have all been used for both engines when they were used for either, and their internal ratios do not change. The exception to this was when Ford moved to the 6.0 about a year and a half before the 3V V10.
Dude I'm stupid not retarded. I know what transmission is where. I posted gear ration in said transmissions. I'm saying that transmission doesn't apply to me. 2 totally different trucks.
  #10015
Oxman504's Avatar
Oxman504
If your trying to say that a 2011 V10 can out pull a 2001 PSD then I will 100% agree with you.
Old Dec 10, 2010 | 05:20 PM
  #10016
Oxman504's Avatar
Oxman504
Your truck doesn't have that transmission, and neither does any V10. But the F150 your talking about does, and the 6.2 and 6.7 have the same ratios. Even with the lower rear gear ratios they usually have, either gas engine will be able to move the truck at the same speed at least one gear lower than the diesel. If the same rear is used, the gas engines will be able to go two gears lower at some speeds.
The 5R110 did change ratios I think in 2005, 1st 2nd and 3rd got taller gears. I remember reading about it just don't remeber where.
Old Dec 10, 2010 | 05:22 PM
  #10017
exiled's Avatar
exiled
Originally Posted by Crazy001
91, 92, and 93 were not "powerstroke" trucks. They were naturally aspirated, and not direct injected. They are known as IDI trucks for InDirect Ignition.
In 1993 and 1994(I think) they had a turbocharged IDI engine, but still no "powerstroke." I think it was late in '94 when the first Power Stroke came out as a direct-injected turbocharged diesel engine.
Sorry I was asking Bill why he thought lower rpms = lower pulling power.
Yall it was nice swapping wits, I'm checking out. I don't have anything else to add to the thread. Hope it sees another 10,000 post.
Old Dec 10, 2010 | 05:26 PM
  #10018
David N.'s Avatar
David N.
You said the V10 was not engineered to handle medium duty use. I said that Ford thinks it is, and Krewat provided the proof. I don't know what else you're trying to read into it.
Old Dec 10, 2010 | 05:32 PM
  #10019
Oxman504's Avatar
Oxman504
I was wrong about what they rated it for. I don't consider them to be Medium-Heavy Duty, Medium-Light Duty yes.
  #10020
David N.'s Avatar
David N.
If all you're want to do is get a stationary load moving, then torque is all you have to worry about. But if you want to move that load at anything approaching highway speeds, you'll have to be concerned about power sooner or later.
